Sub amp trouble
Old Apr 25, 2006 | 11:45 PM
sliderg35's Avatar
Sub amp trouble
I added an amplifier for a new sub that I installed by simply removing the old flat speaker and preamp. I used my own power wire for the new amp from the battery and I used the blue wire for remote on. Everything seemed OK when I tested before finalizing the connections, but after install, the output seems to be dead. Is there a fuze for this somewhere or did I fry the circuit? If I use the rear right channel for input to the sub amp, everything is OK (with a slight buzz at low volume).
Old Apr 28, 2006 | 04:33 PM
sliderg35's Avatar
Anyone? (You know, the white and black wire coming out of the Bose amp.) All you guys who have put in "monster" subs - what channel are you hooking them up to when you don't replace the factory amp?
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
dseet
Oct 11, 2015 12:40 AM
