bluetooth setup
Old Apr 28, 2006 | 01:27 PM
tjm's Avatar
tjm
bluetooth setup
Here's my issue. My first Motorolla Razr V3 i was able to set up in the g35 no problem. Well that phone crapped out on me, so cingular sent me a new one. the exact same phone. now when i try and do a search for devices it says, "no devices found". I made sure the bluetooth is in the "on" mode, and i cant figure out the problem. Does this sound like a phone issue, or an issue with the car? its really annoying. thanks
Old Apr 28, 2006 | 04:27 PM
sliderg35's Avatar
So, you've been able to tell the phone to look for devices - so far so good. At the same time, you need to tell the car Bluetooth to go into "pairing mode". If you are not in "Pairing Mode" the car will not advertise its existance to your phone. I don't have the factory Bluetooth in my G, so I can't give you the button by button method to enter "Pairing mode", but it is a required step.
Old Apr 28, 2006 | 05:04 PM
tjm's Avatar
tjm
that sounds right to me slider. i remember doing something with "pairing" on original setup now that you speak of it. im gonna do some more screwing with it tonight, and ill post how it turns out. thanks.
Old Apr 28, 2006 | 05:13 PM
malukalu's Avatar
i did the same. .had my phone replaced. there is an option embedded in there to "Replace" a phone.. thats what you want to do
Old Apr 28, 2006 | 06:44 PM
tjm's Avatar
tjm
You were right. What I needed to do, was say "PAIR PHONE" first, so that it put me in the search mode, then hit "find devices" on my phone. problem solved. thanks for the info.
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
AuAltima3.5
Sep 13, 2015 11:48 AM
