getting power wire through the fire wall
Old May 4, 2006 | 09:15 PM
vig352006's Avatar
Unhappy getting power wire through the fire wall
Can anyone tell me the best and easiest location to get the power wire through the fire wall of the 2006 coupe?
Old May 4, 2006 | 09:49 PM
tantura's Avatar
There is a huge grommit behind the battery; just poke it trough down into the car!
Don't forget to seal it after...
Old May 4, 2006 | 09:53 PM
R2 V35's Avatar
SEARCH is your friend Noob :-) but, here you go!
https://g35driver.com/forums/showthr...ighlight=power
Old May 4, 2006 | 09:55 PM
KPierson's Avatar
I drilled a hole in the firewall and put a rubber grommet in there. Whatever you do, make sure you seal it up, as water can seep through any opening in that area (I know from personal experiance)
Old May 4, 2006 | 10:33 PM
amg35's Avatar
Florida G35 Club
What have you guys used to seal the grommet behind the battery? Thanks.
Old May 4, 2006 | 10:43 PM
KPierson's Avatar
I went to home depot and got some gasket sealent stuff. I seemed to seal up pretty well.
Old May 28, 2006 | 09:30 PM
dukieman23's Avatar
did you guys run your power wire on the passenger side as well or brought it over to the driver side? i believe all the input/output wires going to the bose amp are ran through the passenger side. Do you think i will get that whining noise if i ran my power down the passenger side? I just thought of this, wondering if i should switch sides but it will be a hassel.
Old May 28, 2006 | 10:21 PM
saitcho's Avatar
bose system uses balanced inputs so noise from the bose HU to amp should not be a problem. i ran my wires on the right side without issues.
Old May 29, 2006 | 02:55 AM
shooter's Avatar
It's not the critic......
Here is a shot of my install with the power wire punched through the wire loom grommet and sealed with silicone sealant.
Danielek
Oct 7, 2015 09:59 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
AuAltima3.5
Sep 12, 2015 08:21 AM
zcherub
Sep 10, 2015 12:03 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
