new kenwood ddx 6019
Old May 8, 2006 | 01:01 AM
Psycraft's Avatar
im really thinkign about getting this set up,i know i need a double din conversion kit and also relocate the ac controls..quick question though,if i do this install,will i still be able to use the buttons on my steering wheel to turn up the music,and turn it down and switch through tracks?
Old May 8, 2006 | 01:05 AM
cmayer's Avatar
you will need to order the steering wheel controls either from peripheral or pac. peripheral model number PESWIAKJ
Old May 8, 2006 | 01:12 AM
Psycraft's Avatar
i need new steering wheel controls? god how much is that gonna be?
Old May 8, 2006 | 01:31 AM
k67p67's Avatar
He meant that you need an interface module to allow you to retain the steering wheel controls. I think you'll need the PAC SWI-X since the Kenwood site makes no mention of that head unit being "steering wheel control ready". The SWI-X is a learning module that utilizes an IR transmitter and learns functions from the Kenwood IR remote. PAC
Old May 8, 2006 | 01:32 AM
Psycraft's Avatar
and what module is this? any link or website i can go to
Old May 8, 2006 | 01:36 AM
k67p67's Avatar
See edit above.
Old May 8, 2006 | 01:47 AM
Psycraft's Avatar
ok perfect thank you,it looks lieka cheap module only 43 bucks on ebay
=cD
Old May 8, 2006 | 02:00 AM
escobar929's Avatar
can you also use a swi-alp?
Old May 8, 2006 | 02:32 AM
cmayer's Avatar
sorry, yes i meant steering wheel inteface. that HU should have a wired remote input like the ddx-7017 so you should be able to use the one i mentioned above. I have not installed one yet so i am not 100% sure, if not just use the swi-x.
Old May 8, 2006 | 02:55 AM
k67p67's Avatar
The SWI-ALP works for Kenwood head units that are steering wheel remote ready. I didn't see that feature on the spec list on the Kenwood site for the DDX-6019. Does anyone know if the unit in question has that feature?
Old May 8, 2006 | 03:41 AM
Psycraft's Avatar
i know the kenwood unit is only like 2 weeks old
Old May 8, 2006 | 01:37 PM
cmayer's Avatar
i have one on order so i will know soon.
Old May 8, 2006 | 06:24 PM
TheDoG35's Avatar
Looks like it has the blue/yellow remote wire, you should be able to use the wired PAC
http://akamaipix.crutchfield.com/Man...113DDX6019.PDF
Old May 8, 2006 | 08:23 PM
k67p67's Avatar
There's your answer. Good work DoG. So, I would guess the PAC SWI-ALP will work with this unit.
Old May 8, 2006 | 09:31 PM
woshiagni's Avatar
Yes, it has the wired remote line. Installing mine this weekend, will see how the SWI-ALP turns out
EDIT: Oops, didn't mean to sound like a broken record. Thanks, thedog. I wanted to add though, that only the newer revisions of the SWI-ALP support Kenwoods and JVCs. The old one (see pic at cardomain.com/shop) only supports Alpines.
