Someone help with tweeter capacitor selection
Old Sep 14, 2003 | 09:25 PM
Koni's Avatar
I want to replace my tweeters so I bought the Image Dynamics NX30 tweets but they dont have the crossover capacitor. The recommended crossover is 24dB/octave at 1600-2400 Hz.
Since I don't know much about this stuff, can someone tell me what capacitors I should get and where they might sell them in the LA area ? Can't wait too install these tweets.
Old Sep 14, 2003 | 09:27 PM
Koni's Avatar
Re: Someone help with tweeter capacitor selection
Oops too = to
Old Sep 14, 2003 | 09:34 PM
rbozzmanee's Avatar
I would ask BillR, he seems to know what he's talking about when it comes to this stuff.
Bozz
6MT Laser Red w/ prem.
Old Sep 15, 2003 | 03:27 AM
PAC's Avatar
PAC
You need capacitors and coils to achieve a 24dB /octave. You can download our Crossovers made easy book from our website.
Old Sep 15, 2003 | 07:52 AM
BillR's Avatar
Koni,
In an "ideal" situation, a 24db crossover is great. That is why they list such a low "recommended" crossover point. However that would require you to build a pretty extensive crossover. Trying to make one is kinda tough.
If you want to crossover low, you can put the following capacitor in line. For a 2000hz crossover use: 19.88uF (4 ohm) or a 22uF for a crossover at 1807Hz.
I would personally recommend that you crossover a bit higher and use a 10.0 uF cap for a crossover point @ 3975Hz.
Using the recommended caps I have listed should get you some decent sound. Those silk dome tweeters should sound really decent.
BillR
Old Sep 15, 2003 | 11:55 PM
Koni's Avatar
BillR,
Thanks for your recommendation. I'm going to take your suggestion and install the 10.0 uF cap. Now I just need to find a shop in Socal where they sell them.
Thanks again.
Old Sep 16, 2003 | 12:30 AM
narkotic's Avatar
[censored]... capasitors? I think the local icecream man sells em' these days.
Old Sep 16, 2003 | 01:02 AM
Koni's Avatar
[censored] a, I'll try the icream man next time I see one.
Old Sep 16, 2003 | 08:58 AM
BillR's Avatar
Try Radio Shack or ANY custom car stereo specialty shop.
BillR
Old Sep 16, 2003 | 09:56 AM
Koni's Avatar
I'm gonna pick them up today.
Thanks
Old Sep 16, 2003 | 11:56 PM
Koni's Avatar
I found this website. Seems to have all the information I needed. You gotta check this out!
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Old Sep 18, 2003 | 02:33 AM
bkchang79's Avatar
koni that website is the sh$t. I've been using that website for years. If you live by westminster, check out JK electronics, they have everything there.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
Old Oct 16, 2003 | 02:10 PM
imsboi's Avatar
Where did you find the stock tweeter capacitor on the door???
Old Oct 16, 2003 | 03:27 PM
Koni's Avatar
It's attached to the tweeter.
g.spot
May 9, 2016 10:54 PM
JustinMKN1
Sep 18, 2015 03:40 PM
