simple and effective way to increase midbass response in the stock door location
Old May 9, 2006 | 05:49 PM
16psibrick's Avatar
as you know, i am a big proponent of kick panels, to me the advtange of doing kicks is night and day improvement over stock locations.
the main advantages to me are: increased midbass response, power handling, imaging and staging...
but i also understand that some will always prefer to have speakres in the door. after doing a few Gs and Zs wit stock door locations, i honestly am disappointed at the midbass response out of the stock location. midbass is soft and not defined.
so i conjured up a simple albeit effective way to solve this issue.
the main problem with the stock door location is that its free air, like subs, midbass speakres can produce a lot cleaner lower frequencys by having some kind of enclosure, where as when the speaker cone moves, the air behind it provide some kine of pressured cushioning, giving hte speaker more control over its movement, thus more defined, tighter midbass.
so...basically what i made is a little pod that sits inside the door and provides this enclsoure for hte speakres.
1. cut out the trim ring out of 1/2" mdf
2. secure it to a foam baffle, cut out the bottom to the appropriate depths for hte speakres, nice thing about DLS speakers is that they are shallow
3. fiberglass the baffle so it becomes rigid
4. dampen the inside of hte baffle with liquid dampening
5. thick carpeted bottom. the reason why idont go fully sealed is that i have always found when there is a semi-permiable membrane on the enclosure for the speaker to breath through, it creates less of a build up in the 100-200 hz range while sacrificing little interms of midbass. think of it as a poor mans AP vent
so here is what hte pod looks like, its definetly not pretty, but not mean tto be at all
basically,t he idea is, slip tis into the stock location first, and secure it to the car
then secure the sepaker to the pod, here you see the midbass of a DLS iridium set
and done, i tested it on antoher car and man, does it make a big difference
just wanted to share
Old May 9, 2006 | 05:50 PM
16psibrick's Avatar
of course this will in no means give you better imaging and staging, and wont prevent any kind of door vibrations, but it does give you good midbass, wchih to me at least, it the single worst offense of hte stock location
Old May 9, 2006 | 06:23 PM
SI_G35Coupe's Avatar
bing, if you made these babies with an MDF ring that could mount right up to the mounting points that the stock speakers use and secure with the same bolts, i bet you'd be selling them like hotcakes to DIY'ers. these are the MDF rings i made for my Polk db6500 comps...
Old May 9, 2006 | 06:30 PM
16psibrick's Avatar
i thought about that, i can utilize a friend who has a CNC machine to mass produce the wooden part hmm
we will see, right now, so overloaded with other prodjcts, unless people realy wants them...
but they do involve a bit of work to finish (despite looking crappy lol), about 4 hours easy on each set...so i mean heck, if i were to sell them, they would be pretty expesniv...not usre if there is much of a market for that
Old May 10, 2006 | 04:20 AM
grizzly's Avatar
dayum that looks sooo GHETTO!
Originally Posted by 16psibrick
unless people realy wants them... if i were to sell them, they would be pretty expesniv...not usre if there is much of a market for that
count me in for a pair to install my UP6
Old May 10, 2006 | 12:05 PM
16psibrick's Avatar
hehe yeah i know, isnt it the ultimate ghetto look? lol ductape for the win!
but it works lol...
once i get a few more of these built, i will figure out a way to make them look more...uh appealin
b
Old May 10, 2006 | 12:39 PM
opimax's Avatar
I am almost sure i would buy, even expensive but cheaper is better
Mark
Old May 10, 2006 | 12:54 PM
amthar's Avatar
I'd buy a set.
Old May 10, 2006 | 02:20 PM
el_duderino's Avatar
You can accomplish the same thing with the right spacer stack and using the thick foam weatherstripping at Home Depot.
Of course, if you're disappointed in the midbass response of the UR6s, its QTS is much more suited for enclosures than for doors. I was disappointed in the UR midbass in some cars also...That's why the UP is my ticket.
Old May 10, 2006 | 03:36 PM
amthar's Avatar
For me it's not as much a possibility of better performance as it looks and feels like a cleaner solution.
Old May 11, 2006 | 12:51 PM
myst's Avatar
Hey el_duderino,
I was wondering if you still have pictures of the UP6 with the weatherstripping on it. I would like to see how you did it so I can do it for my car.
Thanks in advance.
Old May 11, 2006 | 08:09 PM
Originally Posted by myst
Hey el_duderino,
Thanks in advance.
I will dig some up...
Old May 11, 2006 | 08:19 PM
khsonic03's Avatar
What material did you use for the "carpeting"? Almost looks like a thick felt.
EnCr1pt3d
Jul 8, 2019 02:48 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
