Installing Sirius Radio?
Old May 9, 2006 | 06:06 PM
GThIrtYFiZle's Avatar
I am looking to put Sirius Satellite radio in my car. I have an 06 it it is already pre installed. Do you guys know somewhere good in NYC that can do the job. Im a bit skeptical of having just anyone take off the whole middle panel and working with it. I would like to have someone good do it. If you guys can help I would appreciate it. Dealer asked 599 plus tax to do it. I think that is a bit pricy. A local place by me said 200. They have done other work on my other car but I wont let them do it on this because I ont think they are the best. Can anyone help please.
Old May 9, 2006 | 08:08 PM
Mike_Deezy's Avatar
Why would you have to take out the middle console if it's already prewired? It's really easy to do, really straight forward. Basically all you have to do it plug in the tuner and run the antenna. What's your email address, I can email you the instructions. I say you save yourself a couple hundred bucks and do the install yourself, but then again that's all up to you.
Old May 10, 2006 | 08:59 AM
Beowulf's Avatar
Dude it takes 20 minutes to do it yourself if you put the antenna on the rear-deck... The unit goes in the trunk under the plastic cover next to the spare tire...
Old May 10, 2006 | 09:08 AM
spudly's Avatar
I put my antenna on the trunk lid. there is a grommet on the passenger side to feed thru and more then enough cable.
Old May 10, 2006 | 06:03 PM
Is there anyway to keep the antenna inside? I want to put it behind the rearview mirror. I dont want anythink on my roof or trunk. Basically I dont want the antenna to show. Is there a way to do so? And also, you dont have to take the middle console out at all to get behind the radio correct? Everything is dont in the trunk?
Old May 10, 2006 | 06:05 PM
Oh and 1 more thing?? Do you guys think its worth it?
Old May 10, 2006 | 06:41 PM
Mike_Deezy's Avatar
I don't think that it's going to be possible to mount the antenna behind the rear view mirror, not unless you extend the antenna wire to run from the tuner in the trunk to the rear view mirror. Too much work I think. Just mount it on your rear deck lid and be done with it, it's a lot easier that way.
Old May 10, 2006 | 06:48 PM
Ok, Mike, where is the easiest and quickest way to get this from if you dont mind me asking?
Old May 10, 2006 | 06:49 PM
Do you have any pics of how this looks?
Old May 10, 2006 | 07:28 PM
Mike_Deezy's Avatar
Sorry, no pics of antenna on the rear deck. I mounted mine on the roof of my car. You can kind of see it here:
Old May 11, 2006 | 08:23 AM
Beowulf's Avatar
Just put it inside on the rear deck in the place of the child seat anchor. Everything is done in the trunk area. It works fine through the rear window as long as you don't put on metallic tint
WillisFL
Dec 29, 2016 08:56 AM
Frostbite91
Aug 20, 2015 07:20 PM
Frostbite91
Aug 12, 2015 05:16 PM
wuppiedog
Aug 7, 2015 11:16 AM
Tom_P
Jul 24, 2015 04:05 PM
