regarding the *retrofit* SAT 'pre-wire' cable
Old Sep 17, 2003 | 05:20 PM
THX723's Avatar
G Kreuzer
How is this cable wired? Let's disregard the larger 10-pin 'pass through' harness portion (used to tap 12v power source?) and just look at the 12-pin harness on either end of the cable. Is this a simple straight through *exntesion* (from head-unit end to the trunk end)? ... or did any pins get swapped in the process? Yes, I'm aware the harness are diff from both end, but they have the same basic pin-out format.
Thanks in advance.
THX723
Old Sep 17, 2003 | 10:09 PM
narkotic's Avatar
Re: regarding the *retrofit* SAT 'pre-wire' cable
Hey THX. I think i'ts a different pin-out... I looked at the harness end (in the trunk) and the wires are completely different than the ones on the radio, which unfortuantly means in order for me to hack around I need to pull the radio.
Old Sep 17, 2003 | 10:48 PM
THX723's Avatar
G Kreuzer
Yeah ... I'd figure the pin-outs would of been changed. That sucks. We'll have to find someone who just purchased the *retro kit* cable and have them check it before they install it.
Anyone out there who owns the cable that is still uninstalled?
THX723
Old Sep 26, 2003 | 01:04 AM
DC_G35's Avatar
Check out the investigation muran0 has done on the SAT connection for a Murano:
http://members.rogers.com/muran0/Main.htm
He has included a cable drawing.
Also check the fresh alloy thread:
http://forums.freshalloy.com/ubbthre...rt=&PHPSESSID=
Dave
03 G35 Coupe, Black/Graphite, 5AT
Dallsinghjr1
Sep 17, 2023 11:25 AM
Hogbone
Sep 28, 2015 06:44 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
ENTRAPM3NT
Sep 16, 2015 01:21 AM
