Autocross/Road SCCA Solo II Grand-Am Cup, JGTC , Procar SCCA Club Racing, Redline Track Events, Speed Trial, Speed Ventures
Any Sedans with 17x9's + 275 tires?
Old Jun 5, 2006 | 07:18 PM
lead_foot's Avatar
Calculations have lead me to believe that this combo works on all 4 corners with a 35 offset, but I want to confirm with someone that has done it to make sure before I purchase. Thanks!
Old Jun 5, 2006 | 11:30 PM
obender66's Avatar
you need to elaborate-what exact size you are planning to use?
Old Jun 5, 2006 | 11:35 PM
ttrank's Avatar
Grocery getter
They would not work on the front of my car (lowered 1.2). I rub 245's from time to time if I hit a bump and my wheel is turned all the way.
Now that is on 20's so it may work for you.
I have 20x10's +43 with 275/30's on the rear and I had to roll my fenders to fit them.
Old Jun 6, 2006 | 07:33 AM
timm's Avatar
This is the setup I have on my coupe, no issues except a slight rub at full compression with the wheel turned. I can't verify the sedan clearance.
Old Jun 6, 2006 | 09:29 AM
lead_foot's Avatar
What are you missing, the wheel height?
17x9 wheels with a +35 offset, with Kumho v710 275/40/17.
I currently run the 245/45/17's on 17x8's with no problems.
Thanks!
Old Jun 8, 2006 | 10:27 AM
godmans's Avatar
isn't 245/40/17 alot smaller than the stock size?
I am on 245/40/18 which is already smaller than the stock overall size by around 3%
Old Jun 8, 2006 | 11:11 AM
lead_foot's Avatar
Not sure where you're seeing 245/40/17. I'm running 245/45/17 and I'm looking to go wider with the 275 size. Kumho only makes the v710 275 width tire in the 275/40/17 size which is why I'm looking for a 17x9 that will work.
Old Jun 8, 2006 | 03:02 PM
godmans's Avatar
but do you think that the new setup that you have look overall a bit smaller than stock? cause using the tire size calculator, a 245/45/17 is still smaller than a 215/55/17 which is the stock size of 03/04 g sedans...
IMO, if I go any lower in terms of tire size, I would think it looks kind of weird.. that my fender is not being filled properly..
thanks for the clarification tho
Old Jun 8, 2006 | 03:21 PM
trey.hutcheson's Avatar
I don't think he cares what it looks like. This is for autocross.
Old Jun 8, 2006 | 03:27 PM
lead_foot's Avatar
He's absolutely right. I have regular tires on an alternate set of wheels.
Thanks!
Old Jun 18, 2006 | 05:30 PM
Gsedan35's Avatar
18x9 with a 35mm offset will not work, you'll need 30mm in order to clear the suspension in the front with a 275 wide tire.
Here's a couple of links to see a picture of 275/40-18's mounted on 18x9 42mm offset with 12mm spacers, taken from inside the front wheel well.
http://www.sportcompactcarweb.com/pr.../photo_05.html
Notice that his picture still show's some light rubbing going on even with the 30mm offset.
http://www.sportcompactcarweb.com/pr.../photo_04.html
Thing that worries me most about 275 in the front on a sedan has to to with how much tire will stock out of the wheel well. I'd worry about picking up stuff and damaging the paint if you get into the marbles on the track.
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
CJay
Aug 1, 2015 03:57 AM
BlackGee35
Jul 31, 2015 11:04 AM
multimut
Canada
Jul 26, 2015 08:43 PM
