Autocross/Road SCCA Solo II Grand-Am Cup, JGTC , Procar SCCA Club Racing, Redline Track Events, Speed Trial, Speed Ventures
Coupe 19s on '05 Sedan
Old Dec 30, 2008 | 01:24 PM
iceKold's Avatar
I just put a set of Coupe 19s on my 2005 sedan. The main reason was to get more rubber on the ground and lower profile rubber purely for performance reasons (AutoX & Track). The cars is not lowered, everything is stock, I am just curious if I will have rubbing/clearance issues in the rear under heavy cornering. The rear tire/wheel is a good inch taller than the stock sport 18s I had on there before. When mounted, that 1/2 inch less room in wheel well, not to mention the coupe rear wheel is an inch wider also. Throw in the different offset the wheel/tire actually sticks out from the wheel well by a 1/4 inch or so. Just looks like to me it could rub in very aggressive driving. If it does, I guess I could run stiffer sways, but dont really want to start messing around with the suspension setup. I am used to the way it is and feel it is firm enough for now. Any thoughts or experience with larger wheel/tire setups on the sedan and aggressive driving? Thanks.
Nick
Old Dec 30, 2008 | 01:31 PM
Jeff92se's Avatar
Red Card Crew
I run coupe 19s with coupe springs on my 03 sedan. And I've never rubbed. I'm on the oem 245-40-19 RE050s also.
You should be good to go.
Old Jan 18, 2009 | 08:30 PM
infinitcash's Avatar
my springs may be a bit worn when i go over a bump it rubs a little with people in the back seat
Old Jan 18, 2009 | 08:31 PM
I run coupe 19s with coupe springs on my 03 sedan. And I've rubbed. I'm on the oem 245-40-19 RE050s also.
correction i have stock springs
Old Jan 19, 2009 | 12:04 AM
smoovarrowhead's Avatar
IceKold, if your looking for performance for autocross or track, you should stick with a lightweight wheel of 18'' diameter (even 17"). A larger rim diameter will slow you down in the long run as they are usually heavier and take more tire to cover. I went from stock 19's to lightweight 18'' wheels same width of course-and with grippy tires this is a superb setup. The recipe for success is: lose weight, maximize grip, and practice.
Old Jan 19, 2009 | 11:15 PM
Wannabe6MT's Avatar
-MN G Crew-
You wont rub. The only time i rubbed (and im lowered) is if i had weight in the back.
teamghost
Jul 28, 2015 04:52 PM
tiguy99
Jul 26, 2015 01:39 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
