Autocross/Road SCCA Solo II Grand-Am Cup, JGTC , Procar SCCA Club Racing, Redline Track Events, Speed Trial, Speed Ventures
Tire set-up for roadcourse
Old May 29, 2009 | 05:09 PM
soundmike's Avatar
Assuming the same type of tire, is a staggered set-up better for the course, or a non-staggered set-up?
I'm currently on non-staggered but still have the OEM set-up which is. I'm not sure which set of tires/wheels to use at the track.
Thanks.
Old May 30, 2009 | 10:30 AM
Matt93SE's Avatar
What brand/model and size of tires are on each? I wouldn't really worry about the sizes as much as I would the type and condition.
Old May 30, 2009 | 10:49 AM
soundmike's Avatar
Hey Matt!
The OEM is a bit worn in the back but the setup is 225/50 and 245/45, all 18's. The non-staggered set-up is 245/40/19s all around and have plenty of tread left. Both sets are summer.
Old May 30, 2009 | 11:08 AM
darnelled's Avatar
I run 245-45-18's on all wheels to cut understeer.
Old May 31, 2009 | 01:20 PM
smoovarrowhead's Avatar
^^definately better for understeer but takes you out of stock. I would only suggest going to 35/40 series tire instead of 45. (stiffer sidewall). Practice on a good summer tire for your first year then move to a R-comp race tire for better grip when you learn the limits on street tire. Get the lightest rim you can find...
Old May 31, 2009 | 10:29 PM
popcornten's Avatar
I'm in the same boat as Mike. Planning on using my same OEM wheels for track duty.
My rears are also quite worn. Pretty much to the wear bars. I would assume that even though the tread is very worn they will still handle just fine on a dry track/autox course. Do tires only lose their traction in water by losing the tread? Race cars run slicks - so wouldn't worn tires be fine and actually handle better since there's more contact patch?
Old Jun 1, 2009 | 03:39 PM
darnelled's Avatar
Racing slicks are made from a much softer, stickier rubber that don't last very long. You may not be allowed onto a track with badly worn tires. They always inspect the cars where I go.
Old Jun 1, 2009 | 06:28 PM
popcornten's Avatar
That's what I'm really worried about. If they say something about it, maybe I'll be able to beg and get away with it for this one event. If not, I'm out the cash for the event and I gotta find some used OEMs
Old Jun 1, 2009 | 08:32 PM
You might as well wait until you can get tires, bald street tires will ruin your day, spinouts likely. If you plan to keep autocrossing, extra race wheels and tires will be key. If you plan just to race once in a great while, just use good street tires on your oems.
Old Jun 1, 2009 | 09:14 PM
popcornten's Avatar
I am talking about my extra set. They came off my car much balder than I was expecting when I put on my new set of daily wheels/tires. Honestly, I'm just hoping to get away with them this weekend since I'm already signed up. It'll only be my second autox event and first in this car, so I'm not gonna go crazy. Gonna be more about learning how the car handles the course
Old Jun 1, 2009 | 09:31 PM
Qbrozen's Avatar
If you're talking SCCA solo rules, it would only take you out of stock if the wheels were not factory size. The tire size doesn't matter if it fits on factory size wheels.
Old Jun 2, 2009 | 07:29 AM
soundmike's Avatar
If it's that worn, you might have traction problems on a road course. Tirerack does say that slightly worn tires provide better dry traction than new tires, but if it's down that low you might want to skip it. From what i've read and depending on the type of rubber, it's easy to eat up a few mm of tread while on the course.
AutoX is a different matter though, and though i'm not an expert, you can probably get away with it for a lap or two.
Old Jun 2, 2009 | 09:31 AM
mIKE's Avatar
Tire compound changes as you get to the bald stage; yes, you have a larger contact patch, but the compound at the base of the tire is not the sticky stuff that gives you grip. It is there as a foundation for the tread.
If you are at the wear bars, you will probably have less grip. Most tires have optimal grip at about 4/32" tread. Wear bars are at 2/32". Most street tires are between 9/32" and 11/32" brand new.
As for stagger and non-stagger, do you like the factory handling? Going non-stagger will make the front grip harder, and the rear end will break out, resulting in a car that will oversteer. Keeping the staggered setup will maintain the (relative) factory balance. The question here would be, are you running any type of coilovers, BBK, and aero? That is all a factor in tire sizing in a performance application.
If this is your first track day, then stick to the OEM setup, and determine what you like and do not like about your car's handling before making changes. I'd recommend you get a set of high performance pads if you're on a high-speed course.
Feel free to PM me or call with questions.
Old Jun 2, 2009 | 10:01 AM
soundmike's Avatar
Thanks, mIKE.
Everything is OEM on my car except the tires/wheels. I haven't driven on the OEM tire/wheel in a year, roughly 20k miles. I've actually got quite used to the aftermarket set-up. In any case, thanks for the good advice, if i can i'll probably take both sets with me and swap them out. Then again, i probably won't be taking those turns as fast i can, mainly because this is my first time, it's not a race, and there's still much to be learned!
Old Jun 2, 2009 | 11:10 AM
mIKE's Avatar
What kind of tires are on your aftermarket rims? Also, what are the sizes?
Are your OEM rims also mounted with OEM tires? Are they the 17/18/19?
