Autocross/Road SCCA Solo II Grand-Am Cup, JGTC , Procar SCCA Club Racing, Redline Track Events, Speed Trial, Speed Ventures
AutoX Tires for Stock 18" Wheels?
Old Aug 19, 2005 | 06:44 PM
G35Maxedout's Avatar
FS: OEM 18" W-n-T
I plan on using my Stock set of 18" wheels on my brembo G. What tires & sizes should I get that are readily available. Toyo's, Hoosiers, Kuhmo, BFG ????
Thanks for the help.
Old Aug 19, 2005 | 07:19 PM
Pwoz's Avatar
If you are staying in BS I believe you have to get the exact same size tires.
Old Aug 19, 2005 | 07:24 PM
FS: OEM 18" W-n-T
Tire Size
I can use ANY size tire on the Stock Rim Size. I was planning on using a 245/40-18 or a 255/35-18. I just don't know what tires ppl are using on the 18" x 8" wheels.
Old Aug 19, 2005 | 07:45 PM
G35_TX's Avatar
Actually, per SCCA rule book, you MUST stay in STOCK sizes or optional sizes that come with the car for that year. You can not upgrade the wheel size, go wider, or anything with the wheel or TIRE. It must be equal to the stock sizes.
Here is a tire that is becoming very popular in the scca world...
http://www.falkentire.com/tires_rt215.htm
Very sticky tire.
Old Aug 19, 2005 | 09:15 PM
FS: OEM 18" W-n-T
Too bad that it doesn't come in an 18" diameter.
Old Aug 19, 2005 | 09:31 PM
FS: OEM 18" W-n-T
SCCA Tire Rule
As per 2005 SCCA AutoX Rulebook page 64 and I quote:
Tire must fit the allowable wheels and fender wells without modification.
Old Aug 20, 2005 | 01:38 PM
FS: OEM 18" W-n-T
AutoX Tires - What ya think?
Dunlop AutoX Tires
Can I use these 255/35-18 all the way around on stock 18"x8" wheels?
Old Sep 28, 2005 | 11:20 PM
Lucino's Avatar
I believe the proper size on a 8" wide wheel is 245mm, a 255mm will fit but it was intended for 8.5" wide wheels.
Old Sep 28, 2005 | 11:24 PM
Triple8Sol's Avatar
I'm running 275's on my race 17's, so I think you'll be ok with the 255's on the 8"
As for staying in BS, I think they're right. However, it doesn't sound like you care what class you're in...
bu villain
19 Inch
Nov 15, 2015 09:23 PM
CJay
Aug 1, 2015 03:57 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
realtalk21
Jul 20, 2015 09:07 AM
nascarbuff17
Jul 16, 2015 10:23 AM
