Autocross/Road SCCA Solo II Grand-Am Cup, JGTC , Procar SCCA Club Racing, Redline Track Events, Speed Trial, Speed Ventures
Need pads for my 05 G35 6mt Sedan
Old Mar 9, 2006 | 01:11 PM
G35_TX's Avatar
Okay, we do have the 888 pad. Which is the SAME pad on the Q45/M35/M45 vehicles. No aftermarket high performance pads are available except the R4S.
And this is per carbotech! .
Damn I might just have to buy factory replacements for backup. Ugg.
Old Mar 9, 2006 | 01:39 PM
myG35ZX's Avatar
Last year I bought 4 sets of front pads, 3 for the rear and 3 sets of rotors. For five track events, I used 2 sets of pads on the front, 1 on the rear and all of the rotors for the front. ChicagoX took the temp of my rotor at RA and it was over 500 degrees. I guess this year will be the same!
Old Mar 9, 2006 | 01:50 PM
Balzz's Avatar
Originally Posted by G35_TX
I called Wendy and 129 for the front and 79 for the rear for R4S. They have to make the R4 pads and it will increase the price dramtically. I really don't want to spend that much on pads for only the track when I hardly will ever go.
Hence....Money ----> heat & noise.
Old Apr 24, 2006 | 06:09 PM
RacingBrake's Avatar
Originally Posted by Balzz
Just order a pad with FMSI # 888 in the front and 588 in the rear. Porterfield definitely makes them in both R4S and R4 compounds (that's what I ran last year). Carbotech will make them too.
What was the outcome of the fitment for the new G35 models (05-06) pads? Did anyone install the pads: D888 Front & D588 Rear?
The older G35 non-Brembo (03-04) used the D815 Front & D905 Rear.
I have yet to find a pad for the 05/06 G. No brake pads or rotors are available other than OE. If you find one, please post it. Stoptech may be coming out with a rotor replacement. But I know of no company with plans for a pad.
We will have stock replacement performance rotors available to the market shortly for the 05-06 G35's / 2006 350Z.
Old Jul 3, 2006 | 10:37 AM
vodkarocket's Avatar
Modded Member
^RacingBrake, any update to this yet?
Old Jul 3, 2006 | 01:11 PM
G35_TX's Avatar
http://forums.freshalloy.com/showthr...highlight=hawk
See my post a little further down for part numbers for Hawk HPS pads. I was testing them for Racing Brake and measured my stock pads and they sent me the correct ones that should work. They did.
FYI, ther rear brakes on the 05-06 G35 use the same pads as the 03-04 G35.
Old Jul 5, 2006 | 11:00 AM
jeremybhm's Avatar
update to pad/rotor saga
So Racing Brake has this part # for the front rotor, 9161-141, which looks like it is the right size, but they don't have the rear rotor that I can find which is supposed to be 12.1 inches for the 05-06 6mt sedan, correct?
The Hawk part numbers are
Front HB387F.547
REAR HB370F.559
So all that is missing is a cross-drilled/slotted rear rotor... Any ideas?
(edit: racing brake replied w/ the part number)
9169-141
http://forums.racingbrake.com/viewtopic.php?p=604#604
Last edited by jeremybhm; Jul 5, 2006 at 12:19 PM. Reason: update from racing brake
Old Jul 20, 2006 | 12:56 AM
Modded Member
^So these part numbers for both pads and rotors are for the 05-06 sedans/coupes?
Please confirm.
Old Jul 24, 2006 | 09:30 AM
NickS's Avatar
I might be a little late to the game here but I've talked with Carbotech and Stoptech and they are all telling me that there are no aftermarket pads available for the 05-06 brakes yet. No "track appropriate pads" is more accurate. Yes there are aftermarket OEM style pads available.
I've been to 2 track events so far and both times I had brake fade and boild the brake fluid. And this was after installing S.S. lines and Motul RBF 600.
The OEM pads a crap and can't even hold up to a minimum amount of heat.
My options are to send a set of backing plates to Carbotech and they will put on any material I want but at a price.
So an update on this subject would be appreciated.
Old Jul 24, 2006 | 12:30 PM
G35_TX's Avatar
Contact Hawk. They have pads.
Old Aug 18, 2006 | 11:51 AM
hubertyG35's Avatar
I know a number of people who have run HPS at the track and they fade far too quickly. Does the Hawk HP+ have a fitment for the 05+?
I'm running Brembo's on an 04 and use Carbotech XP8's, and they work like a charm (but, as carbotech isn't an option I'll shut up about those), and would definately suggest these for track events if they ever become available.
Old Aug 18, 2006 | 11:52 AM
NickS's Avatar
Carbotech will put any of their compounds on ANY set of backing plates. Just get a spare set of plates, send them to Carbotech and you will have track pads. Done deal.
Old Aug 18, 2006 | 07:45 PM
G35_TX's Avatar
I agree, they do fade very fast, but slightly better than stock.
Old Dec 22, 2007 | 10:43 PM
GWord256's Avatar
Hope I'm not beating a dead horse with this thread. But I'm looking for a light-duty track/autocross pad for my '07 coupe. I'm pretty new at this and I've found pads for the 03+04 non-brembos, are the 07 coupes the same size pads?
Old Dec 22, 2007 | 11:03 PM
  #30
Texasscout's Avatar
http://www.ebcbrakes.com/Automotive.html
