DIY: Headlight housing Removal
Old Nov 6, 2007 | 04:08 PM
diablo1356's Avatar
maybe a stupid question...but how do you remove the ballasts? im getting projectors soon and i need my original ballasts for the new lights..
Old Nov 6, 2007 | 04:21 PM
filanj's Avatar
There are 3 screws on the outside (maybe a 4th). That will disconnect it from the housing. On the inside there is a tiny screw holding the harness onto the ballast. Take that out, then disconnect the harness. That is all.
Old Nov 7, 2007 | 04:09 AM
Fassster10's Avatar
this by far has been the best DIY for the headlights, very nice...thanks a ton...
Old Nov 10, 2007 | 01:04 PM
Mr_pharmD's Avatar
how u take off the grill? I pop off the 4 tabs but the damn thing wont come loose. I cant seem to get the clip off the top on both sides without breaking it.
Old Nov 10, 2007 | 02:51 PM
filanj's Avatar
Use a flathead screwdriver and pop up the tabs. After that all you need to do is be careful. I start at one side and press against the bumper with one hand. "Tap" the base of the inside of the grill and it should work its way out. There are 4-6 slots that the base of the grill slides into. Those are what you need to focus on.
Old Dec 21, 2007 | 04:28 AM
GeeDM's Avatar
Amazing, simply amazing..the best write up ever and its right on time, i plan on painting my headlight bezels this weekend.
Old Dec 21, 2007 | 06:22 AM
BuckeyeG's Avatar
Very nice DIY thanks
Old Dec 27, 2007 | 03:01 AM
mynes's Avatar
wow what a great write up i need to start on mine
Old Dec 29, 2007 | 01:25 PM
WTF??'s Avatar
The write up is definitely good...... but a bit deceiving for those who have oem bumpers.... its even more of a b**ch to reach that inner bolt through the wheel well
Old Apr 14, 2008 | 07:28 PM
Sinister350GT's Avatar
Thanks !! THis took me all of 20 Min to change out my 03 lights to 06 lights.
Old May 3, 2008 | 10:49 PM
Red_G35's Avatar
so what happens to the harness for the clearance lights on the 03-05 when you install the 06-07>? Do you use that for the city lights?
Old May 12, 2008 | 01:13 PM
Mine was a straight swap everything fit where it should
Old Jun 7, 2008 | 08:39 PM
nismog35driver's Avatar
Hi, I tried this today but for some reason I can't seem to unclip the harness. The other thing is that the wires are so short that the headlights only move out by an inch. Any ideas?
Old Jun 23, 2008 | 08:53 PM
Kensi's Avatar
Hey.. just wonderinng.. im from vancouver, canada.. do i need to do some rewireing inorder to work? or is it plug and play.. also if i do need to rewire anyone have the DIY?
Old Jun 24, 2008 | 05:35 AM
  #30
No need to rewire, just plug and play.
