DIY: G35 Hood Damper by Caskyline
Old Aug 7, 2010 | 07:55 PM
  #166
nate704's Avatar
can you post some detailed pictures?
Old Aug 7, 2010 | 09:21 PM
  #167
AustinG35's Avatar
wrapping up tonight, I just need to purchase some double-sided tape to finish the installation of the 2 hood hinge plastic pieces. I will take some pics tomorrow.
Old Aug 11, 2010 | 01:44 AM
  #168
AustinG35's Avatar
So even after I dremelled out the two areas (red arrows) where the shock had pushed the plastic down when the hood is closed, it appears that the shocks simply rest even lower at that point now, but I guess that means that there is less tension on the shocks than before. I also included a couple of pics of the hood mounting cover and how I modified it to fit around the NRG mounting bracket for a more OEM appearance.
The JDM battery cover for the left side seems to have some mounting issues when adding the shock to the left side. The JDM battery cover actually sits a little higher on this side than on the right side.
Attached Thumbnails DIY: G35 Hood Damper by Caskyline-dsc03390.jpg   DIY: G35 Hood Damper by Caskyline-dsc03391.jpg   DIY: G35 Hood Damper by Caskyline-dsc03392.jpg   DIY: G35 Hood Damper by Caskyline-dsc03393.jpg   DIY: G35 Hood Damper by Caskyline-dsc03394.jpg
Old Aug 11, 2010 | 09:26 AM
  #169
AustinG35's Avatar
Some more pics:
Attached Thumbnails DIY: G35 Hood Damper by Caskyline-dsc03395.jpg   DIY: G35 Hood Damper by Caskyline-dsc03396.jpg
Old Aug 21, 2010 | 07:45 PM
  #170
QuadCam's Avatar
has anyone else had a probolem with these hood dampers being too stiff.....resulting in bend hood hinges?
I bought these NRG hood dampers a few years ago....when they first came out. Over time, they ended up bending my hood hinges due to the excessive force needed to close the hood now. Finally, after a couple years of this abuse on the hood hinges, my hood clearance between the hood and the fenders (up near the hinges) reduced to nothing........resulting in my hood catchon the corners of the fenders, bending them up like they were put in a can opener! :-(
Looks like I'm going to have to buy new hood hinges and have both fenders and the hood repaired and repainted.
Did NRG end up changing the valving/strength in these hood dampers from what the early ones were? or has this happened to anyone else?
Old Nov 23, 2010 | 11:57 AM
  #171
broke_as_ajoke's Avatar
nice DIY looks real easy
Old Mar 4, 2011 | 01:37 AM
  #172
sillyoldtayo's Avatar
i had the same problem as AustinG35^^^. I had to trim the passenger side(jdm) battery cover rubber trimming as the damper would not lay correctly, resulting in my hood being elevated about 1/8". Great thread!
Old Mar 4, 2011 | 02:20 AM
  #173
nissandrifter32's Avatar
Gonna order mine soon.
Old Apr 4, 2011 | 10:10 AM
  #174
G35xAngel's Avatar
anyone know where to get good hood dampers for under $100????
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
brycealbr
Aug 11, 2015 11:47 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
