DIY: How to Properly Aim 06+ Coupe Projectors
Old 08-08-2008, 04:52 PM
thechronic's Avatar
if anyone is wondering...you turn the screw to the right for the headlight to aim higher, and left for it to go lower
  #62
Old 08-23-2008, 12:10 PM
V35 Skyline GT's Avatar
6MT Coupe
Nice write-up. Thanx for the dia and number crunching. Just did a recent bezel mod and last night seems off from original aiming so will check and adjust per your method.
  #63
Old 09-23-2008, 10:27 PM
mpapers's Avatar
OK, so i just aimed my 06 recall lights and everything is good except the driver side is about 20 degrees from being flat. Is there anyway to adjust that?
  #64
Old 12-18-2008, 03:43 PM
erklep's Avatar
someone needs to post this on hondatech forums! damn ricers with 10000k ebay hids in halogen reflector housings!!
  #65
Old 01-08-2009, 03:26 PM
anDross's Avatar
is there any way to fix an angle for the projector
  #66
Old 01-08-2009, 06:53 PM
redlude97's Avatar
You have to take them apart, and maybe that will fix them. THIS IS EXACTLY WHY THEY WERE RECALLED! Please stop buying recalled projectors!
  #67
Old 01-22-2009, 03:35 AM
anDross's Avatar
apparently my adjustment screw isn't moving my projector... it's like when you tighten a screw, and the thread get loose.
can anyone help a brotha' out? any possible fix? i don't know what to do
  #68
Old 01-22-2009, 03:36 AM
anDross's Avatar
the left side is working... however the right side is just turning without any up/down movement on the projector itself.
  #69
Old 04-16-2009, 01:03 PM
qpdo1's Avatar
How is it that you adjust simply the slope such that the lower cutoff and the upper cutoff differs by the ~2.5" spec. The headlights are aligned vertically i.e. the height to center of lens is the same at 25' and they are not / or \ it is just the difference is closer to 4.5". Any suggestions?
qpdo
  #70
Old 05-05-2009, 02:48 AM
truexh's Avatar
where is the screw to aim the headlight left and right?
  #71
Old 05-05-2009, 03:07 AM
HenryLee's Avatar
nice write up!
  #72
Old 05-05-2009, 04:22 PM
IvoryGT's Avatar
left and right screws can't be reached without removing the lights.
  #73
Old 05-05-2009, 04:36 PM
truexh's Avatar
i figures... thanks
  #74
Old 05-05-2009, 04:50 PM
RRG35's Avatar
good detail
  #75
Old 06-03-2009, 09:13 PM
nyckid's Avatar
can someone post an actual picture with the projectors shining at a wall 25ft away with correct aim so i can see how the line is suppose to exactly look?
________________________
is it suppose to look like this ________________________/
or like this _________________________________________________
Quick Reply: DIY: How to Properly Aim 06+ Coupe Projectors
