DIY: $135 OEM Spoiler Install
Old Jan 6, 2008 | 09:21 AM
Texasscout's Avatar
Very well done! Who wants to do a sedan now?
Old Jan 28, 2009 | 01:35 AM
imaGinaG's Avatar
Touch up paint around the holes will also prevent rust and not look as bad as the primer considering that 4 holes will show outside of the mat!!!! great job though!
Old Feb 12, 2009 | 05:25 PM
jetdoc's Avatar
Good thread, I am going to be getting my spoiler soon.
Old Feb 12, 2009 | 07:27 PM
mistaanime's Avatar
haha good writeup..
Old Feb 12, 2009 | 07:28 PM
Dr. AL's Avatar
nicely done. although i still wouldn't trust myself with a drill haha. good job tho!
Old Feb 17, 2009 | 09:57 PM
zeroragnarok's Avatar
show pics of the completed install!
Old Feb 20, 2009 | 07:03 PM
AesonVirus's Avatar
I would have polished that trunk lid first... Holy Swirls Batman!
Nice write-up.
You should post some finished install pics.
Old Mar 3, 2009 | 07:11 PM
gtd86's Avatar
A point to add... im sure all g35's come with the boot prewired for the spoiler brakelight, the wiring harness that runs to the lock, there should be an unused connector wrapped up, that is a brake light connector. Just tap those 2 wires, saves running wires down through rubber connector and wiring into 3rd brake light in window. Would still just disconnect the plug for the 3rd brake light in window to give the same effect.
Also... a must! Make sure you cover the sides of the rear of the car and probably the majority of the boot to stop the shavings from the drill hitting the paint work, there a nightmare to get off, as they will scratch the paint. i think also if there hot from drilling they sink into the paintwork a bit, they will rust up real quick and make a mess! Sadly this never occured to me when i installed mine, and now i have quite a few tiny spots on the rear part of car!
Old Sep 6, 2009 | 07:08 PM
Raymen's Avatar
Excellent DIY. I just installed the spoiler on my car following these steps and the final result was great. The hardest part for me was putting on the four end screws. If you're not careful they could end up in between the two trunk metal layers (happened to me, lol). Anyway, thanks for the write up.
Old Feb 14, 2016 | 07:10 AM
jznsn2u's Avatar
Sweet write up!
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
nickmcc123
Jul 29, 2015 05:14 PM
joedaddy1
Jul 28, 2015 02:58 PM
