DIY: NRG Hood Props Installed
Old Oct 21, 2008 | 03:45 PM
sanchezj666's Avatar
I recently added a set of Polished NRG Hood Props on my '04 Coupe. I followed the directions given from Infiniti Help.com
http://www.infinitihelp.com/diy/gsed...stallation.htm
The installation didn't happen exactly like the video. When I shut the hood after the props were installed there was no problems, but when I raised the hood it chipped paint off my fenders. I ended up loosening all four bolts and re-aligning the hood so I wouldn't rub anymore. I still open the hood slowly and like having the access to the engine bay without the original hood prop.
Old Oct 21, 2008 | 03:50 PM
MikeYo's Avatar
ummm ok?
Old Oct 21, 2008 | 05:43 PM
ttrank's Avatar
Grocery getter
And you feel the instructions could be inproved how?
Old Oct 21, 2008 | 06:23 PM
This post was just to inform people how things went when I installed this modification. As with all "mods" and aftermarket applications, things can happen different then normally should. The instructions were awesome! I think my hood was stressed from heat/wear, so when I loosened the two bolts it ended up relieving some tension and the hood shifted, causing it to rub my fenders.
Old Oct 23, 2008 | 12:35 PM
Tru-G's Avatar
Never heard of hood dampeners taking the paint off a fender. Wow!
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Albanian122
Sep 18, 2015 06:01 PM
PZ06G
Interior
Aug 24, 2015 06:27 PM
brycealbr
Aug 11, 2015 11:47 AM
