Coupe taillight removal?
Old Mar 24, 2009 | 08:34 PM
| 1cleanG |'s Avatar
Am i dumb, or is there a trick to removing the tails? I just don't want to break any clips or anything....and i can't find a writeup on it? I found headlights and sedan tails, but not coupe tails?
Please help! Step by step or pix of how to remove coupe tails?? THANKS!
Old Mar 24, 2009 | 08:47 PM
O HELLA OEM's Avatar
open your trunk
you know that black plastic piece in the middle
pull that off..then pull back the grey carpet thing behind the taillights...there like 3-4 screws on each taillight..unscrew them then unclip the harness and pull the taillight out
its hard to explain on writing
i think i should make a DIY Removing Taillights
GL
Old Mar 27, 2009 | 12:50 PM
GR8TG35's Avatar
I was wondering the same thing....one of my side marker bulbs went out, and the stealership want over $30 to replace the bulb..... I know theres a couple nuts holding on the tail, and I figured out how to remove the plastic anchor fastners......but I'm afraid I will break the black plastic pc that goes along the edge of the trunk.....How is that fastened? Do you simply pull straight up, or do you need to pull that pc from its side outward to release the clips? I figure if I bust that pc, it will cost me alot more than the $30+ they want to replace the bulb....any help would be greatly appreciated.
Never Mind, I figured it out...you need to pull straight up on the black finisher pc, and lift it up out of the way to get at the remaining nut that holds the taillight in place.
Old Mar 28, 2009 | 07:40 PM
wxp-g35's Avatar
just pull it straight up. the clips just pop out with the plastic piece. and then when u put it back in you just snap the peice back in.
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Xanthan Gum
Aug 6, 2015 10:49 AM
Frostbite91
Jul 27, 2015 05:25 AM
lemmy999
Jul 25, 2015 12:13 PM
