Haven't seen this problem on here
Old May 4, 2009 | 09:13 PM
Ameen's Avatar
I've done a quick search and I can't really find the same problem here so here we go...
So for the past year, sometimes my window wouldn't go back up when it went all the way down..so every once in awhile, i would clean the motor and so on, but finally I decided to change up the whole motor instead of always cleaning it. Today my new window motor arrived and I installed it. The window goes down perfectly fine, but when it goes up, it seems like it is about to die. Once it gets halfway up, it seems like it does not have enough power to bring it all the way up (but everytime, it still makes it up slowly). As well, when I put it up with the "auto up," it gets half way and stops and goes down just a little bit and stops. I am very confused, any help would be greatly appreciated!
Old May 4, 2009 | 09:29 PM
KSWAY's Avatar
Try resetting your window regulator...
Old May 4, 2009 | 09:53 PM
Ameen's Avatar
Is that the button on the window motor?
I forgot to add, that I also did the full reset on the new window motor so it moves the half on inch up and down when i open and close the doors.
Old May 11, 2009 | 05:57 AM
0V3RC10CK3D's Avatar
Pull up the plastic piece surrounding the shift boot.
Wrap a washcloth around the metal shift rod below the shift boot.
Clamp vicegrips to metal rod with washcloth inbetween.
Hold vicegrips in place while you twist the ****.
You want to make sure you don't put strain on the transmission when turning it, that's why you use the vice grips to hold it in place, and you do it under the shift boot as to rip or otherwise maul it.
Old May 11, 2009 | 01:42 PM
Ameen's Avatar
I think you got the wrong thread..
Old May 12, 2009 | 11:19 PM
TroysG's Avatar
no I think he's talking about the window motor
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
Jnm07
Sep 5, 2015 01:16 AM
