clock lite/heated seat lite
Old Jun 29, 2009 | 10:58 AM
CanadianBird's Avatar
Is it difficult to change the lite in the clock/'03 G Sedan? Also, is it difficult to change the lite in the passenger side heated seat indicator switch. Both are out. Thanks
Old Jun 29, 2009 | 10:11 PM
Epidel's Avatar
you mean to a different color or replacement?
Old Jun 30, 2009 | 03:33 PM
Ameen's Avatar
i got the exact same problem. my clock light is out and i just removed the old bulb but infiniti wants a fortune for the set of bulbs. i haven't even attempted to change the bulb for the heated seat light though
Old Jul 4, 2009 | 12:36 AM
jblair083's Avatar
Search the postings for clock light. You can either use a "grain of wheat" bulb or a led. How much trouble did you have getting the plastic moulding off the clock?
Old Jul 6, 2009 | 11:17 AM
I haven't tried to change anything, it just bothers me that those two lites are out. I haven't asked the dealer what it costs to replace them. Not doubt those bandits want an arm and a leg. It doesn't have to be led lighting, just lite.If I turn the seat heating on, the light works, but when in neutral, the lite is off.
Old Jul 6, 2009 | 11:37 AM
shipsaeki's Avatar
what year is your car? The heated seat switch is not supposed to illuminate. only the little line turns on to indicate that the switch is in the on position.
The clock light is very easy. I recommend taking it to the dealership if you're covered under warranty because those bulbs are a little hard to find in stores. if you must change it yourself, just get a flathead screw driver wrapped with cloth and pop the triangular trim piece around the clock and temperature unit. Once removed, unclip the harnesses LED for the security light and the clock. when you remove that, on the back of the clock you will see 2 white plastic screws which are the bulbs.
Old Jul 8, 2009 | 06:06 PM
mackinboi's Avatar
um no it illuminates at night. and yea mines is broken too...
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
doakley92
Sep 25, 2015 12:58 PM
pasjr1972
Sep 1, 2015 10:17 PM
