Passenger Window Problem
Old Aug 27, 2009 | 03:44 PM
mr.leekumkee's Avatar
I just bought a new window motor for my passenger side and installed, and i also tried switching the door switch. it is not working so if you guys can give me any ideas on what the problem could be.
Old Aug 27, 2009 | 03:59 PM
specialist's Avatar
did you check the fuse?
Old Aug 27, 2009 | 04:15 PM
yes that was the first thing i did. is the fuse your talking about under the battery
Old Aug 27, 2009 | 05:04 PM
acidjake75's Avatar
Im about to switch my drivers side.. what brand did you get? A refurb or a new one?
Old Aug 28, 2009 | 02:48 PM
i bought the oem factory window motor
Old Aug 28, 2009 | 03:27 PM
acidjake75's Avatar
Was the window at least working a little bit when you swapped it out.? Should be just plug and play. I just changed mine and it worked like a champ. Perhaps you got a bad unit (if you already checked the fuses ect..) check the plug - could have a missing PIN.. I dont know - just throwing some suggestions at ya
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
Jussaku
Interior
Jul 29, 2015 04:13 PM
