For those of you upgrade to 06 tail lights...
Old Feb 8, 2008 | 12:04 PM
cturnbull802's Avatar
Originally Posted by specialist
how about using macro switches? from a microwave? if that does work may be i can use my computstar neg trigger to use to see if the car is unlocked. I can't think of a way to just use factory wireing or tap in to anything.
you actually wouldnt even need a relay..
just tap it into the switch on the dash, then use the micro switch to open one leg of the circuit so it does not work when the car is locked.
i am sure something like this would work,
the gas door would be the easiest since its close
someone give me a set of 06 tails and i will wright up a DIY
Old Apr 7, 2008 | 02:29 PM
Strtsk8r321's Avatar
bump
(2000 posts!!!!!)
Old Jul 18, 2008 | 07:36 AM
civic4982's Avatar
bump any luck with this yet?
Old Jul 18, 2008 | 12:37 PM
someone buy me 06 tails i will make it work. with a diy.
Old Jul 18, 2008 | 01:23 PM
hanguk9117's Avatar
i saw some questions that weren't answered so...
- 06 Tails are direct plug and play. All the bulbs on the 05 Tails fit directly into the 06 Tails. Even the black plastic part on the 05 Tails screw off, and can be directly fitted onto the 06 Tails.
- Some 06 Tails do not come with the trunk button. Thus there is a "hole" where the trunk button should be. I believe one member asked about this. You have to buy the trunk button separately. I bought mine from Rick at Riverside Infiniti.
- As for a DIY in removing the Tail lights...hopefully this short version will help: First remove the plastic trunk liner, it pops out, you just have to directly pull it up. I wish I had a picture...I'm afraid most people won't know what I'm talking about. Then use a flat head screw driver to pop out the black plastic pieces holding in the trunk felt lining (i know pictures would be helpful...). Lastly, there are 3 nuts holding in each taillight. Unscrew them using an 8mm (i think...it could be 9). That's it. Once again I apologize for this rough DIY...but better then nothing right?
Old Jul 18, 2008 | 01:29 PM
civic4982's Avatar
so no one knows how to get the trunk button to work as of yet?
Old Jul 18, 2008 | 01:58 PM
it doesn't address the trunk button operation, and that's what we are talking about.
Old Jul 18, 2008 | 02:08 PM
hanguk9117's Avatar
i saw some questions on the previous page regarding how to remove / install tail lights, and i didn't see any answers so i thought i'd help. i didn't realize those posts were from many months back...so the people asking the questions pbly don't care anymore. haha. my bad.
Old Jul 30, 2008 | 02:26 PM
elrooko's Avatar
Instead of getting 06 tail lights, can you just wire up the micro switch and see if it will work with the wiring. Then in theory, you could just buy the lights and hook the microswitch up to the button somehow.
Old Jul 30, 2008 | 02:45 PM
there could be another way to do it, i have an LED that turns on, on my dash when my car is locked. hook a relay to that circuit so when the led is on, the switch on the trunk would be open. then when its unlocked the relay would close and it would be just like pressing your trunk button inside the car.
Old Sep 25, 2008 | 08:27 PM
1YoungOwner's Avatar
Do anybody know anything about 04'coupe headlight swap with 06' projectors?
Old Sep 25, 2008 | 10:57 PM
Beebo's Avatar
Its plug and play... you can not use the bulbs from your old lights... Do some research... there are plenty of helpful threads
Old Sep 26, 2008 | 01:29 AM
RST531's Avatar
back on topic. how can i wire a mirco switch to get this to work? i tried tapping into the fuel lid wires. just for input to see if anyone can thing of any ideas. what i did was ran a wire from the fuel lid actuator to the button and then the another wire from the button to the power on the trunklid latch. test 1:after pressing the unlock button, i pressed the trunk button and nothing happened. test 2: i just to see, i held the trunk button down and pressed the unlock button and the trunk lid opened. So the fuel lid only gives out a pulse (?) of power in which isnt constant for it to work. but the fuel lid would be good to trigger some kind of relay to be open when locked, and run a wire from the switch inside the cabin to the button. i for one have no experience with wiring or relays and such. i tend to go at it and try different methods. but does anyone know what kinda relay/switch/whatever would work? it would need to be able to use a pulse to close the powered wire. or something that can take 2 pusles, one to open it and the other to close it? sorrry if this confusing but i have no idea what to call these things. but i hope this helps someone to figure this shiat out.
Old Sep 26, 2008 | 08:47 AM
elrooko's Avatar
I was totally thinking the same thing. What we need is some sort of magnetic coil relay. 12V on one side opens the relay, 12V on the other side closes the relay. When the relay is closed, 12V will goto the trunk release. When it is open, nothing happens. Basically, when the "lock" is triggered for the fuel door, the 12V signal will open the coil, when it is unlocked, the 12V signal will close the coil. Something like there. There has to be something online for that. What color wires in the trunk are for the fuel door release?
HOLY CRAP - I think all I we need is to wire up this!!! We just attach coil 1 to the "lock signal" and don't hook up any output. We hook up coil 2 to the unlock signal and run the trunk release and the button to it. What do you think? I'm not an electrical engineer but I think this would work.
https://secure.vividcluster.crox.net...Max=&SUBCATID=
Old Sep 26, 2008 | 11:20 AM
  #30
civic4982's Avatar
nice work guys. I'm excited to see how this turns out.
