For those of you upgrade to 06 tail lights...
Old May 26, 2007 | 12:45 PM
edindaclub's Avatar
i installed my 06 tail lights a month ago, but the thing keeps bothering me is that the trunk buttom on the tail light won't work,i hv a 03 coupe, does anyone of you have the same problem with me?
Old May 26, 2007 | 12:46 PM
Nismo G's Avatar
The trunk button inside the cabin or the one that is on the tail light themselfs?
-Sean
Old May 26, 2007 | 12:55 PM
edindaclub's Avatar
sorry , didnt make myself clear, the trunk release button on the tail light
Old May 26, 2007 | 01:22 PM
Nismo G's Avatar
If you have a 2003 coupe with 2006 tail lights i dont believe their is a plug and play wire for the trunk release. The button won't work for pre- 06 models.
-Sean
Old May 26, 2007 | 01:30 PM
allforthecash's Avatar
-Sean
That is correct....unless you figure out a way to wire it up
Old May 26, 2007 | 01:35 PM
Calvin's Avatar
Overglorified Altima
it'll have to be a custom job
as far as i know, no one has figured it out yet
Old Jun 11, 2007 | 11:45 PM
G2FAST's Avatar
As far as installation does this button interfere? Whats the average price on these tails? Are the lights plug n use?
Old Jun 12, 2007 | 12:28 AM
Gam3's Avatar
how do u install the tails...is there a DIY
Old Dec 6, 2007 | 08:33 PM
thatg's Avatar
yeah same question
Old Dec 6, 2007 | 09:11 PM
Scrooge's Avatar
Can someone show me a picture on what there talking about. I might be able to help.
Old Dec 8, 2007 | 06:32 PM
thatg's Avatar
we just want to know how to remove the tail lights from the car. i just got mine but theres a hole where the buton used to be booo
Old Feb 7, 2008 | 10:18 AM
specialist's Avatar
you could wire it up to the button on your lower left hand dash button but if you lock your car the button will still work. I would love to find out how to do it then i would buy the lights
Old Feb 7, 2008 | 10:20 AM
srsly's Avatar
personally i like the circle reverse light 03-05
Old Feb 8, 2008 | 12:15 AM
cturnbull802's Avatar
shouldnt be that bad.. a limit switch and a relay. maybe use the gas door to sense if the doors locked, m (IE when gas door locked trunk button does not work)
Old Feb 8, 2008 | 11:59 AM
specialist's Avatar
how about using macro switches? from a microwave? if that does work may be i can use my computstar neg trigger to use to see if the car is unlocked. I can't think of a way to just use factory wireing or tap in to anything.
