tail lights painted..(not the lenses)
Old Nov 26, 2008 | 01:59 PM
IrockAG35's Avatar
Ohio G Club moderator
well after making the mistake of trying to bake my driverside tail light,which is the method for seperating the headlights..i had a ruined DS tail light which was no longer of use due to the semi-melted lense lol!. i then found out the tail lights were pressed together with a cement, but could be opened with a dremel tool..since my G is not a DD i decided to try a few things and this is what the results are....enjoy
first started out using the small cutting wheel in the dremel
after about 4 of these cutting wheels, i finally get all the way around..this process takes about an hour per tail light
carfully seperate the housing from the inner plastic peice..this peice is very fraile
there are a few screws inside and out..you will need to remove them all including the ones holding the led circut boards in place and all the lenses..remove all wiring as well(all connected)
then sand the chrome plastic inner,using a 120grit sandpaper..after removing the chrome, use 600-800grit to smooth the surface
wipe clean,then use dupli-color flat black spray paint..takes about 3 coats to completely even out
after drying for about 2hrs..replace all led hardware including all the lenses
i used gorilla glue to re-apply the outter lense(red). but use caution the gorilla glue expands quite a bit..i recommend using headlight/tail light silicon...i then used adjustable straps to hold the tail light together while the glue sat up over night
heres the finished product..hope this info is usefull
Old Nov 26, 2008 | 02:03 PM
G35Ian's Avatar
you should it side by side with a regular tail light...because I really don't see a difference.
Old Nov 26, 2008 | 02:05 PM
G U LATER's Avatar
me neither
Old Nov 26, 2008 | 02:07 PM
ShanesG's Avatar
yeah side by side pic if you can....looks pretty good from what i can see!
Old Nov 26, 2008 | 02:09 PM
G U LATER's Avatar
It was looking good until it got behind the lense.
Old Nov 26, 2008 | 02:11 PM
AggressiveG35's Avatar
Cant see a difference, As previous people have said, Can we see a side by side pic?,
Old Nov 26, 2008 | 02:18 PM
Ghayes23's Avatar
Looks good. I may be trying that at some point.
Old Nov 26, 2008 | 02:19 PM
WhosRich's Avatar
its supposed to be subtle but noticeable on the street. looks clean
Old Nov 26, 2008 | 04:52 PM
Johnmikins's Avatar
Take some pics of it on the car...
Old Nov 26, 2008 | 05:06 PM
IrockAG35's Avatar
id take side by side but i only have one tail light..i can try and find a pic of a reg one
Old Nov 26, 2008 | 05:07 PM
IrockAG35's Avatar
i will do it tomorrow and post a pic..tail light isnt on the car yet
Old Nov 27, 2008 | 09:48 PM
CreativeDesignZ's Avatar
looks great man, not too dark where u will get ur ***** busted and not too light where u cant tell. This is suble and elegant, good work! wanna do mine =]
Old Nov 27, 2008 | 11:04 PM
ILLicit's Avatar
Me and DieselX painted the inside of his taillights this Summer... heres the comparison shots.
Old Nov 27, 2008 | 11:37 PM
Beebo's Avatar
hhhhmmm nice... it just looks darker to me
Old Nov 28, 2008 | 01:15 AM
O HELLA JDM's Avatar
pretty sick
