DIY: Suspension installed
Rating: Thread Rating: 36 votes, 5.00 average.
Old Mar 26, 2007 | 12:28 AM
Skaterbasist's Avatar
Retired SuperMod
Great write up.
Would this DIY also work for the Tein Basics?
Im getting these coilovers in a couple of months, and just like you, do not want to pay 200+ for the install.
Old Apr 20, 2007 | 02:09 AM
rijowysock's Avatar
great DIY, ive always done all my own susp work.. and this DIY is the best ive ever seen anyone make (im always too lazy to take pics and explain, but glad someone did)
riley
Old Aug 3, 2007 | 04:39 PM
kenchan's Avatar
Originally Posted by rwcblkcoupe
hey guys,
Just a note. I just install some tein h-techs today on my 03' coupe. If your planning this install some helpfull hints i found. The factory manual tells you to undo bottom shock bolt and upper mounting isolator..yada yada yada...
at that point they say to remove strut assembly...GOOD LUCK! here is what i did and it made it WAY easier. Remove the lower arm bolt holding the lower suspension on and the sway bar bolt. This will allow the lower part of the suspension to drop out of the way allowing the strut to damm near fall right out. It is two more bolts... saving major time. I did have access to a lift and the job for all four corners took 3 hrs total. Good luck...sorry i took no photos...
Rob
yah, agree with rob on not being able to pull the strut assy out on the
coupes just from collapsing the a-arm. i just used my spring compressor
to compress the assy alittle, then pull it out. also, i collapsed the a-arm
where the cotter pin is. much faster.
Old Aug 3, 2007 | 07:58 PM
Deezflip's Avatar
Is it safe to drive it for two weeks to let the springs settle before getting an alignment? I know in some of my previous hondas, after i lowered it, the toe alignment was affected.
Also, if you anyone needs a spring compressor, some auto part store has free tool rentals, just put a deposit, and when you return it, you get your full deposit back.
Old Aug 6, 2007 | 03:40 PM
kenchan's Avatar
yah, the rear will wander a little bit but you should be okay. just dont
go too fast and make sure you know the limitation of the car until you
get that alignment done.
Old Aug 6, 2007 | 04:20 PM
RBull's Avatar
Rated M
DieselX, good DIY. I like your layman's write up.
Wow, your car is rusty though!
Old Aug 10, 2007 | 12:56 AM
fherjohn's Avatar
man i could not get the bottom bolts off attatched to the sways. i d*mn near stripped em. so if im just replacing the springs, i don't have to take the shock off? just compress it? pics pleasE.. anyone..
Old Oct 7, 2007 | 01:00 PM
thenexlevel's Avatar
I followed those instructions yesterday, back were real easy but on the front after I took out the strut I was not able to remove the springs. The top mount had one nut where you had to hold on to the screw while turning the nut. This made it kind of impossible to use any kind of socket, did you guys have to bring it to the shop and had them use an impact wrench?
Old Oct 7, 2007 | 03:09 PM
nikkaitsme's Avatar
nice write up..i'll be swapping out my 350z h-tech to 350z swift tuesday so i guess i'll be saving me 200 bucks now..lol
Old Oct 17, 2007 | 03:52 PM
g35brother's Avatar
nikkaitsme, you have any pics of your car?
Old Nov 13, 2007 | 12:37 AM
tjlazer's Avatar
I did this the other day. Great write up. I had to swap springs so I had to buy a spring compressor ($10) and I also had to compress the spring to remove it from the car. The new lower springs installed is shorter so I did not have to (re)compress the spring to get it installed. If you break loose the strut bolt under the hood, it helps when you have to remove it once the strut is out. I did not use a vice at all. It was a PITA using the spring compressors though! I just used some elbow grease. 25 turns on each compressor back and forth until spring was compressed enough. Removed old spring, install new springs and recompress to get top mount installed. Lots of work but saved some ca$h and did it myself which is worth it.
DOMO
Old Nov 14, 2007 | 09:25 AM
SilverII's Avatar
nice DIY....
Old Nov 16, 2007 | 10:06 PM
chester's Avatar
imma try this next week.. hope this goes well.. any tips..
Old Dec 1, 2007 | 12:33 AM
chinaman_87's Avatar
damn man just saw this diy this write up makes the install look extremely easy
Old Feb 28, 2008 | 12:40 AM
  #30
swolg35's Avatar
Good write-up! Very thorough!
You have already rated this thread Rating: Thread Rating: 36 votes, 5.00 average.
