Help with DIY Brake Line replacement
Old Oct 27, 2008 | 04:05 PM
bythabay's Avatar
Originally Posted by bythabay
Funny you should ask. Erwin (erdog) and I just got done changing his oil and installing a magnefine AT filter and we filmed the filter install so that's coming up. Next we're filming a rear camber kit install (spc brand) and then I'll be filming a clutch fluid flush and an SS brake line install.
I'll try to get the vids posted asap.
Unfortunately we didn't get around to flushing the clutch fluid or replacing the brake lines. I'll try to get it done next time.
Old Nov 15, 2008 | 05:13 PM
gte959s's Avatar
20 Year Member
yeah it be nice to get a video of this. I'd like to see how you bleed the brakes when you do this.
Old Nov 15, 2008 | 05:32 PM
bythabay's Avatar
Calcul8 (Nathan) and I are installing these right now... he forgot that we needed to record and did his side before I was ready... I'll be doing mine soon though, so I'll makes sure to video that. As for bleeding, I'm just going to use my power bleeder.
Old Nov 17, 2008 | 08:58 AM
gte959s's Avatar
20 Year Member
Show some footage of you using that as well. I am thinking of getting one soon, but wanted to see it in action first.
Old Nov 17, 2008 | 11:45 AM
bythabay's Avatar
I already have video of that. Check the brake flush DIY vid.
Old Oct 14, 2010 | 12:31 AM
WhosRich's Avatar
After searching, I couldnt find a good DIY for this. Anybody have any input on how to do it?
Old Aug 27, 2011 | 11:36 AM
publet's Avatar
I'm also unsure of exactly how to do this. Are you supposed to completely bleed out the brake system before switching the lines or do you not have to?
thanks!
Old Aug 27, 2011 | 11:40 AM
WhosRich's Avatar
Do not empty the all the brake fluid before completion. Its going to cause more problems. Install the lines, THEN bleed the fluid.
Old Aug 27, 2011 | 12:47 PM
publet's Avatar
do you have to plug the steel brake line then? or does it have a leak preventing mechanism?
thanks again!
Old Sep 2, 2011 | 12:49 PM
publet's Avatar
would like to get an answer to the above post...
Old Sep 2, 2011 | 12:56 PM
bythabay's Avatar
I've replaced lines several times and I've never plugged them to prevent fluid leakage. I usually just let all the fluid drain out and then I would just power flush with fresh fluid.
Old Aug 16, 2014 | 05:02 PM
Srdatsun's Avatar
Good info.
How do you power flush the lines?
jsimonk
Dec 22, 2023 03:49 PM
Jussaku
Aug 4, 2015 12:45 PM
RedBaronK
Jul 27, 2015 03:19 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
