350z H-Tech rear gap
Old May 21, 2006 | 10:00 PM
G Thizzle's Avatar
Has anyone with 350z Tein H-Techs noticed a good size gap in the rear? I have these installed on my coupe with 20x10.5 in the rear and the gap looks huge... what do you suggest??? Should i change out my rear springs to S-Techs? Thanks
Old May 21, 2006 | 10:09 PM
dream_G35's Avatar
i hope they settle! i was thinking of getting z htechs myself but that back gap should not be there....WITH 20'S!
Old May 21, 2006 | 10:13 PM
G35SHAWN's Avatar
Give it couple of weeks for the springs to settle..
Old May 22, 2006 | 01:22 AM
Sponger's Avatar
6MT Brembo Coupe
I've been waiting over a year and they still haven't settled
You can try cutting the rear upper boots if you like.
Old May 22, 2006 | 02:04 AM
G35pm's Avatar
The rears on the H-Techs are like stock. Almost no height difference
Old May 22, 2006 | 02:23 AM
GLuXuRy's Avatar
99CL looks like you got your GT-Forces... looks HOT !!! Dang man you got your wheels before i did LOL ... Like everyone said... let it settle for a while... but dont cut anything... if it comes down to you still not liking it after a few weeks just get another set of springs... someone will buy your Htechs
Old May 22, 2006 | 06:36 AM
G Thizzle's Avatar
Thanks for the input... Well the thing about it is that i have had the H-Techs for almost a year now... but i have noticed from taking my wheels on and off that from jacking the car up the gap always re appears.... i hope they settle... Might got with the S-Techs!
Old May 22, 2006 | 10:14 AM
Espresso's Avatar
How much rear wheel gap do you have? I just had the H-techs installed this weekend. Right away, I noticed the fronts had a noticable drop. The rears maybe 1/2" but will need to wait for them to settle and have an alignment.
Old May 22, 2006 | 02:03 PM
G Thizzle's Avatar
right now probably about 2.5 fingers... that is with 20's... like i said i think they will settle...
Old May 22, 2006 | 03:37 PM
mynismoG35's Avatar
so with oem 19s for example this gap will be even larger right...... cuz i ordered 350z tein h tech springs for my g with oem 19s....... and if so do u guys think i should try to get my order changed...... example like get tein s tech springs the actuall ones they have for the g
Old May 22, 2006 | 03:49 PM
Espresso's Avatar
The offsets of the OEM 19" are pretty well tucked into the fenders. It may help to hide some of the wheel gap. With wider aftermarket rims almost flush with the fenders, you may consider a 1" or more drop to "look" better. I went with the 350Z H-techs since I don't want to change out shocks and have to get a camber kit right now. That and I have to clear my driveway. Anything lower than 1" will cause me to scrap. After the alignment, many here with H-techs say you can get it back close to factory specs without a camber kit. It's up to you to decide but going lower may require a camber kit.
Old May 22, 2006 | 03:58 PM
roncfpz's Avatar
Go with the S-Techs instead; this will give you an add'l .4mm drop. I had the H-Techs and switched out to S-Techs; much better stance and only 1 finger of clearance. I did have to cut the fenders though with 20 x 10.5 rims +29mm offset and 285/30/20 Michelins.
Old May 22, 2006 | 07:49 PM
TLS's Avatar
TLS
I dont understand when people said that they got it close to factory spec withOUT camber kit, which spec is this? Theres no camber adjustment on the front or rears. So what kind of adjustment is there to GET it close? Im pretty sure its just the toe that can be dial, other than that its basically the drop is in the range of spec and they consider that " I got it close to spec???"
sorry for off topic
Old May 23, 2006 | 03:43 PM
Espresso's Avatar
^^I'll find out in a week or so if an alignment without any camber kit can be adjusted back to stock spec.
Old May 23, 2006 | 04:22 PM
Hexxum001's Avatar
You have to remember, H Techs only lower your ride approx. 1/2 an inch. The reason people recommend going with Z H Techs is because of a stiffer spring rate. The S Techs will lower your car about an inch all around. If you don't like the gap, get the S Techs.
