General Supsension Question
plz don't flame me or tell me to "search"...
I'm trying to understand the different components and design of the G Coupe suspension. I see a lot of references to springs, adjustable rate springs, adjustable ride height etc. But I still don't understand fully all the issues and options. The Coupe has a 4-wheel multi-link suspension, which looks like a shock with a coil spring around it. Is that what is described as "coil-over"? When folks reference Tein "Basics", that is a replacement for the shock and spring, where the "H-Tech" and "S-Tech" are simply replacement springs over the stock shocks? What are the issues and things to consider when looking at replacing springs only versus replacing the shock and spring together? Just trying to get my wee pea brain wrapped around the concepts here.
Um search? I mean it's really the only way you are going to learn. No infiniti comes stock with coilover suspension.
I mean even reading the stickies in this section would answer 50% of your questions
To humor you: there are 2 stickies in this section, one is information on sway bars (not related to my specific question), the other has what I am sure is very good technical information regarding spring rates of aftermarket suspension parts. I read that "sticky" a number of times before I posted my question. While I am positive this is very good information, it is very specific and does not answer even "50%" of my question. I have a very general question, I would guess there are many members of this forum could answer.
I'm trying to understand the thought process behind people who are so quick to jump on the "do a search first!" bandwagon. Is it some power trip? Do you feel superior in some way by replying that way?
The way I figure it: if you don't know the answer then don't respond. If you do know the answer it prolly takes no more time to reply with the answer, than to reply with "do a search".
It's so funny you want to label me as a teh SEARCHA adviser. Read this:
https://g35driver.com/forums/g35-sedan-v35-2003-06/87276-section-all-sections-really-needs-better-sticky-info.html
But if you asking such basic questions like "do I have coilover type suspension?", then maybe reading your owner's manual would help. Or Infiniti's own dealer marketing flyers.
I KNOW the answer. But just answering is NOT always the fastest way for you to learn. Teach a man how to fish so to speak.
Originally Posted by johnbigbootie
Thanks Mr. Helper. Every web forum, regardless of the subject, is the same <sigh>.
Yes
You had the good-gens. hehe. I had a set of Z trackeditions on. Someone stole the car for them. Insurance totalled it. I threw some Z 18s on, cleaned it up and sold it. Saw it as my opportunity to get out of maximas and took it. Seems like a natural progression?
Originally Posted by max723
i was a member for a while had 2 third gens. i remember yours. great cars but had to move on.
In a nutshell, it's usually money. Springs are the cheapest, springs and shocks are more expensive, but are usually designed to work together, and coilovers add adjustable ride height.
Hey John, since I'll be seeing you at the track this Sun I'll be a nice guy and help you out.
Read this article and then come back if you still have questions.
g35's have coilers for the fronts.... just that they are not height adjustable like those of the aftermarket ones like the tein basics.... for the rear, most aftermarket kits will provide the separate coil spring and shock that are tuned to work together for replacing the components of the factory setup...
there are a few full coilover setup kits where youll get a pair of identical coilover spring shock kit for the rear and not need a coil spring in the factory spring location...
I would be afraid that the rear shock absorber mounts in a G35 were not designed to support the full weight of the car.
https://g35driver.com/forums/showthread.php?t=87276
I don't really consider telling me to search "teaching me to fish", but I guess we'll agree to disagree.
