WILWOOD Specs
Old May 30, 2006 | 09:21 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
WILWOOD Specs
Here's a link to the Wilwood catalogs.
Follow the links for complete tech info including dimension dwgs
Old May 30, 2006 | 10:24 PM
Endless G's Avatar
Are you getting the 4 piston or 6 piston?
Old May 30, 2006 | 10:33 PM
InTgr8r's Avatar
Probably the 6 pot...
If you get the right one (radial mount) it's actually slimmer than the Arizona 4 pot kit.
FROM WILWOOD SPECS dw=disk width; mo=mount offset d>F=disk face to front of caliper
Billet Superlite SL6R Radial Mount (14")- dw=1.25; mo=1.52; d>f=1.79
Billet DynaPro Radial Mount- dw=1.0; mo=1.53; d>f=2.04
IIRC
ARIZONA uses
Billet Superlite SL6R LUG Mount - dw=1.25; mo=1.54; d>f=2.35
Billet Superlite 4R/ST LUG Mount - dw=1.25; mo=1.54; d>f=2.19
Forged Billet Superlite 4 44.5 piston LUG Mount dw=1.25; mo=1.56; d>f=2.15
Old May 30, 2006 | 10:40 PM
Endless G's Avatar
Will this fit over the winters 17"??
Old May 30, 2006 | 10:46 PM
bigwilly's Avatar
Any idea if these slimmer profile calipers will fit over the stock 17x7 +45 offset? I currently use the stockers for my winter setup.
Old May 30, 2006 | 10:47 PM
InTgr8r's Avatar
That's the big question...& will also depend on which OEM for which year too.
But from the dimension dwgs,,, should be able to make a template
Old May 31, 2006 | 09:52 AM
InTgr8r's Avatar
Interesting.....
- don't know specs & if spacers were used.. I'll try to find out.
Old May 31, 2006 | 01:09 PM
Endless G's Avatar
Which one is that Ian!?
Old May 31, 2006 | 01:27 PM
InTgr8r's Avatar
Here....
http://www.350zbrakes.com
I'm waiting for a reply as to which part #s (soooo many)
Old May 31, 2006 | 01:36 PM
G35Lin's Avatar
Multi-Spoked Mod
thats my car AGES ago... :P poor car..
anyways there was NO SPACER involved. STOCK 17" SPORT package. 2003
Hopes that helps.
I got em from: http://www.g35brakes.com/
Ed Lin
Old May 31, 2006 | 01:46 PM
Endless G's Avatar
You dont like the Wilwood??? How were they?!? Were they reasonable?!? I msure it cant be compare to the Endless you have now!!
Old May 31, 2006 | 05:05 PM
G35Lin's Avatar
Multi-Spoked Mod
hahaha. i went through so many BBKs. i swear....
well, the wilwoods were ok. not bad for a bbk. i liked the stoptechs better myself tho. I think with the 13.1" stoptechs you can run 17s on there i believe. maybe not. someone verify this.
The kit was actually great for the price but i felt that the stopping power was just ok and not great. They are reasonable for the price. If you need to have ur 17s, i would get the wilwoods. thats one reason i got em.
However, when i took it to my shop to dismount them, they had some complaints about the kit. i forget what those complaints were tho. but anyways. i think its a pretty decent kit....
Ed Lin
Old May 31, 2006 | 06:09 PM
Endless G's Avatar
Can you run 6 piston in the Stoptech 13.1"???
Old May 31, 2006 | 06:17 PM
StopTech's Avatar
Our 6 piston setup is only available for 355mm rotors
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
