Worn Out Brake Pads And Rotors Did This To My Volks. Pics Inside!
Old Jun 7, 2006 | 02:23 PM
bigwilly's Avatar
What about the Mothers Powerball that Chip Foose is pimping out, anyone give that a try? Maybe that combined with some good aluminum polish.
Old Jun 7, 2006 | 04:28 PM
Diesel1's Avatar
Moderator
I think if you take apart the wheel, you should first know the torque specs used so you have the proper setting when you reinstall. The last thing you want is your hoop n tire to go in one direction while you try to drive on teh center portion.
Also, I think most Volks have annodized lips. If that's the case, I would avoid anything that is abrasive. Just do one wheel at a time with an annodize safe cleaner and take your time.
Old Jun 7, 2006 | 04:29 PM
Zerk's Avatar
I would use a hose and spray the $hit out of that before doing anything. Those little metal chips can do a lot of damage.
Old Jun 7, 2006 | 10:00 PM
jjyellow's Avatar
take it to a car wash with the pressure hose and clean out the corners. I do it all the time and it works great.
Old Jun 8, 2006 | 12:56 PM
sen_jen's Avatar
Meatshake Enterprise
again, these wheels are anodized clear coated. if you polish them out, you'll see a burn mark where the spokes meet the labia. however, if you take them apart and polish them they won't be too bad. you will lose the look anodized gives off.
you can't use metal polish on the labias. it's the same treatment you would use on the exterior body of your car. clear coated surfaces.
Old Jun 8, 2006 | 03:16 PM
khsonic03's Avatar
Hey...sorry to see that. Try a clay bar. It will work just like it does on paint. I used it on my volks because they had a little rust and tar on them. It worked like magic, and didn't damage the rim. You can also get into the crevices pretty well because the clay molds into the surface. Good luck.
Old Jun 8, 2006 | 06:29 PM
JDMFairllady21's Avatar
damn i cant believe you even let the wheels get dirty to that point... good luck regardless
miata007
Aug 17, 2015 04:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
