Need help.
Old Jun 19, 2006 | 08:12 PM
GThIrtYFiZle's Avatar
Need help. Someone please photoshop.
Is there anyway to make the paint on the caliper look nice and glossy when its done instead of dull. Is the paint already glossy or is there a different product that can be put on. The body shop I think will spray mine with a special paint they said. I appreciate any help. The paint will be white, almost to match the IP. Can anyone please photoshop the white calipers on a IP. And if possible put black infiniti and red infiniti lettering on another pic. Thank You.
Old Jun 20, 2006 | 10:09 PM
kenchan's Avatar
there are clear coats that can sustain high temperatures.
Old Jun 21, 2006 | 06:10 PM
do you by any chane know any names of them.
Old Jun 22, 2006 | 11:19 AM
sliderg35's Avatar
I bought some paint that was specifically for "Calipers". It said you had to get the temperature of the calipers up to 200 degrees for the paint to cure properly (no problem there) They are really quite glossy. (I did put about 5 coats on though.)
Old Jun 22, 2006 | 05:50 PM
you did it yourself?
Whats the name of the paint. Looks really good. Thanx.
Old Jun 23, 2006 | 12:16 PM
sliderg35's Avatar
Yep - I didn't even have to take the calipers off. I just removed the wheels and used a wire brush attachment on a drill and some break cleaning solution to to clean off the calipers. (Watch out for the rubber boots on the calipers) I masked off everything I didn't want to paint out to about 2 feet from the calipers and sprayed away. Very thin coats. While I was waiting for one coat to dry, I would go to the other side and prep/paint that one.
I got the paint at Canadian Tire. I'll check the name on the can when I get home.
Jcruzg35
Sep 26, 2015 04:47 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
FRUG35
Sep 11, 2015 03:07 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
