caliper clamping question
Old Jun 23, 2006 | 03:28 AM
mazzona19's Avatar
What is the reason for replacing the stock calipers? Is their clamping force not suffiecient to take advantage of the larger rotors? Or is the weight the defining factor. I am trying to decided if I should get only rotors and pads instead of a full kit. Thanks
Old Jun 23, 2006 | 06:33 AM
speeddreamz's Avatar
Basically, people want bigger calipers for bigger or more pistons which = more stopping force. It also means bigger rotors which also translate to more surface area to disappate heat and help it stop. The G is heavy, so bigger brakes are nice when you make more power, i.e. supercharger/turbo or heavy N/A work. Or .if you're doing track duty offten.
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
mushu
Jul 15, 2015 03:55 PM
