What camber kit do you use? Recommendations plz
Old Jun 24, 2006 | 04:18 PM
Jining's Avatar
Just wondering what camber kits you guys are using. The stillen one seems a bit pricy... kinetix looks pretty good, but are there any other alternatives? Thanks!
Old Jun 25, 2006 | 02:06 PM
Andy2434's Avatar
For the rear, I plan on using the SPC camber and toe kit.
Old Jun 25, 2006 | 02:13 PM
MixturePinoy's Avatar
I ordered the SPC. hopefully it's good. it was pretty cheap on ebay
Old Jun 25, 2006 | 07:02 PM
bocatrip's Avatar
Re: allowing camber adjustment
Is there any camber kit available for the G35 Coupe with standard suspension to decrease the negative camber that is not a total replacement for the control arms? I just want to correct the inside feathering issue with my front tires without having to change my front end. My alignment guy (master tech) suggests modifying the black brackets on the lower control arms to allow more lateral movement (widening the openings by drilling them wider to allow a slot) to reduce the negative camber. I'm not sure about going that route. Aren't there any brackets for the front to adapt to either the upper or lower control arms (without replacing them) to allow some camber adjustment? Any help would be appreciated.
Old Jun 26, 2006 | 12:29 AM
GReddySetGO's Avatar
Front: Cusco
Rear: Kinetix
Old Jun 28, 2006 | 02:37 PM
partshipperdave's Avatar
The SPC rear camber/toe kit we have on sale will set you up to adjust the camber + or - 4 degrees, and the toe can be adjusted + or - 3 degrees.
And it's a much cheaper solution to some of the other kits out there!
Old Jun 28, 2006 | 11:39 PM
SFLG35's Avatar
FGC President
i have the full kinetix kit
works great but hte front constantly squeeks.
if i were to buy new i would get the rear spc kit and either the new version of the kinetix (i have the old version) or if you could hold off until spc releases their front arms i would wait for those.
Old Jun 29, 2006 | 12:37 AM
richboy's Avatar
MORE POWER PLZ!!!
I don't have camber kits on my ride yet. But when i drop the G i am planning on getting the 350evo (fronts) and Stillen (rears).
Old Jun 29, 2006 | 01:13 AM
Andy2434's Avatar
That's exactly what I am waiting on.
Old Jun 29, 2006 | 01:50 AM
808HerbzG35's Avatar
I'm currently on Cusco A-Arms (-4) and BattleVersion rear camber/toe arms (-1.3).
^yupz, go for spc.
Old Jul 1, 2006 | 06:11 PM
synaptik_1's Avatar
Any word on when SPC is gonna release their front kit?
Old Jul 2, 2006 | 12:07 AM
SFLG35's Avatar
FGC President
should be soon. im pretty sure the last time i talked to peter he said begining of july.
Old Jul 2, 2006 | 12:45 AM
GLuXuRy's Avatar
im getting SPC also for the rear
Old Jul 4, 2006 | 05:27 PM
G35sedan03's Avatar
I've got SPC for the rear and was about t buy the 350evo a-arms for the front. I heard of the SPC kit for the front and i'm waiting for that one. SPC and 350evo are the best for our cars, but dpending on your application, maybe you do want negative camber, maybe the others will do for you.
Old Jul 5, 2006 | 10:54 AM
I have contacted SPC for an update and will let everyone know as soon as I hear back from them. As soon as they're available and we can get our hands on them, we'll have them on sale!
