Tein Springs
Old Jun 29, 2006 | 01:28 PM
O HELLA JDM's Avatar
Tein Springs
yo just wondering whats the opinion out there for the tein S tech springs or teh tein H tech springs...any difference....or what springs can me pretty good size drop but still have good handeling performance....thanks
Old Jun 29, 2006 | 01:59 PM
kenchan's Avatar
im fine with the S-Tech's front springs, but the rear sucked for my taste.
i'd try the hotchikis and 350Z H-techs if it wasn't for my current setup.
otherwise, maybe the 400lbs or less coilovers
Old Jun 29, 2006 | 04:12 PM
w0ady's Avatar
fgc moderator
i think im going with 350z h-techs. similar ride to stock, slightly improved handling and gets rid of that wheel gap without having to worry too much about scraping.
Old Jun 29, 2006 | 04:31 PM
GReddySetGO's Avatar
Word, 350Z H. Techs will probably suite your needs best. I kinda wish I went that route now instead of my S. Techs. But oh well, coilovers are in my future
Old Jun 29, 2006 | 07:32 PM
patman530's Avatar
If you want to see what 350Z H-techs look like installed:
https://g35driver.com/forums/brakes-suspension/105830-05-6mt-coupe-tein-350z-h-tech-install-pics-before-after.html
Old Jun 30, 2006 | 12:43 AM
MD_V35's Avatar
Why are you guys not satisfied with the s techs? Is the ride quality bad?
Old Jun 30, 2006 | 04:07 AM
sick sick thanks guy i might go h tech...ill find out how much i get h tech for should be around 150 plus install right...install should cost less than 400 right...asking around so i dont get ripped off...if anyone knows people in san diego...message me up thanks
Old Jun 30, 2006 | 06:21 AM
patman530's Avatar
I paid 200 for 350Z H-techs, (i know that is too much), but i only paid 75 for the install, done at Gruppe-S in Hayward
Old Jun 30, 2006 | 12:01 PM
superdds's Avatar
the spring rates for the rears are too soft on the s techs. they're even softer than oem so you're going to introduce more roll transfer to the front thereby increasing understeer.
Old Jun 30, 2006 | 01:53 PM
Rookie84's Avatar
I have never been a fan of progressive springs, which S-techs are. I am about to order Z H-techs as well and pair them with revised Z-shocks. I only heard great things about H-techs.
Old Jul 4, 2006 | 05:58 AM
wyatthanson's Avatar
Hey guys.. Kind of a thread jack, so I apologize.
But what springs would give the G35c the biggest drop without needing camber plates and other alignment tools? Also nothing SOFTER than stock, preferably a stiff spring.
The H-Tech sounds great, but I want to know if there is a lower spring available.
I am new to the G world. Coming from an S2000 world.
Old Jul 5, 2006 | 09:28 AM
SFLG35's Avatar
FGC President
the tanabe springs are stiff and drop the car about 2 inches, tein s techs for a 350z are about the same in drop and are stiffer then stock. the eibachs can get you pretty low as well but are progressive rate.
all tein g35 springs are softer then stock.
Old Jul 6, 2006 | 01:12 AM
Are H&R progressive or linear? I think they drop about as low as Eibachs, which seems to be the max before alignment tools are needed.
Old Jul 7, 2006 | 01:46 PM
Hieroglyphics's Avatar
Wouldn't those first drops you mentioned require a camber kit though? If not I'll prob be in the market for the 350z s.tech. I understand that the car is a luxury coupe, but I'm also coming from an S2000 world and so the ride is a little too soft for my tastes.
You also stated that the s.techs for the g35 coupe are softer than stock. Do you know what the stock spring rates are for a g35 coupe with sport suspension?
Old Jul 7, 2006 | 03:11 PM
shifter's Avatar
I'm about to order the 350Z H-Tech Springs for my 06MT Coupe and wanted to confirm if this is the right springs to get. Thanks.
http://www.intensepower.com/tehsp35.html
