Kinetix or Cusco A-arms
Old Jul 14, 2006 | 08:31 AM
ATL_Red_G35's Avatar
If your front toe is in good specs and the camber is not that much of then I'd stick around for the SPC new front camber sets in two months.
I've had SPC before and I'd stick by their products
Old Jul 14, 2006 | 09:50 AM
Mike_Deezy's Avatar
+1 I have always used SPC camber kits on previous cars and have no complaints about them at all. I too am waiting for the fronts.
Old Jul 14, 2006 | 01:22 PM
Andy2434's Avatar
Waiting for the SPC front set-up, as well.
Old Jul 14, 2006 | 08:46 PM
wa2good's Avatar
I am in the process of engeniering and then manufacturing our very own VRT line of suspension components for these cars (Z's and G's) coilovers, front and rear camber arms/links, etc. Testing some prototypes right now! On our front upper controll arms, they will be made to adjust more than most out there, for the maximum added negative and positive camber. I will keep everyone posted on the progress.
Old Jul 22, 2006 | 07:36 PM
s130turbo's Avatar
even with the SPC, you might find you cannot get both camber and toe back to factory specs - hard to say for sure, as there are alot of variables that are specific to your car that its hard to visualize without being there. They will get you very close though, that's for sure
As for the Cusco's, they may or may not provide the adjustment level you need - that's where the wheel offset and tires really come into play, as they have a big effect on your final alignment numbers and how much adjustment you need to get back to a factory or close to factory specs. I would not say they won't come close though, as many have proven otherwise (I've got them on my car, with a 2 inch drop, a moderate wheel package, and can get down to within factory specs at max positive adjustment on the a arms). I've played around with a variety of camber settings in front and rear, and chose to run higher than factory camber (about 2 degrees per side)
When it's all said and done, make sure your toe is back to a factory spec. Some additional negative camber over the factory spec is not only acceptable, but desirable, as it really helps these cars out.
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
DRG35R
Sep 16, 2015 05:33 AM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
Freedz
Aug 28, 2015 07:38 PM
NohoG35revup
Aug 22, 2015 12:13 PM
