Brake pad bed-in
Old Jul 13, 2006 | 10:39 AM
kashrahman's Avatar
Brake pad bed-in
so when I've had aftermarket pads/rotors on other cars, a bed-in procedure
was always recommended (several stops from 60-10, cooling off in between).
Is this also recommended for stock pads/rotors? I went to tirerack, and their recommendation depends on which pad/rotor you have.
http://www.tirerack.com/brakes/tech/....jsp?techid=85
thoughts? advice? I did this when I got G35X #1 when new, can't remember if I did it with #2. thanks, Kash
Old Jul 22, 2006 | 12:15 PM
G35 Mass's Avatar
I did a very proper very complete bed-in process, and I can not believe the braking quality, smoothness, etc.
It was well worth the multiple car trips using only gear-braking and the parking brake to stop before I could complete the process
Old Jul 22, 2006 | 08:32 PM
Montara's Avatar
From Nissans TSB on Armada and Titan brake repair.
It does make a differance.
Classification: Reference: Date:
BR04-003e NTB04-066e August 29, 2005
2004 - 2005 TITAN AND ARMADA; BRAKE JUDDER
Burnish the Brake Pads
A. Drive the vehicle on a straight smooth road at about 30 mph (50 kph).
B. Use medium brake pedal/foot effort to bring the vehicle to a complete stop from
about 30 mph (50 kph). Adjust your pedal/foot pressure so that the vehicle stopping
time is 3-5 seconds.
C. Cool the brake system by driving at about 30 mph (50 kph) for approximately one
minute without stopping.
D. Repeat A, B and C (above) ten times to complete the burnishing process.
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
