ARC Front Strut Bar...help?
Originally Posted by Triple8Sol
No FSTB will ever work w/my Stillen blower
I have designed a version of one of my G35 STB's that fits perfectly with the Stillen SC, I've been using it for a while and it works great....
PM me if you would like to order one.......
Originally Posted by kenchan
i think it has to be made out of strong material like titanium in order
to have the rigidity as the arc. you make it out of stainless at that
thickness, probably be just a dressup conversation piece for nothing
but dressup.
but dressup.
here is a little teaser picture for you guys
Originally Posted by richie
feels pretty good to me
good for you.kinda like driving around with wheelmax wheels that look like
Volks and SSR's. lol. but it's your car.
as long as it does the job, it's fine with me
im going to be taking down the pictures (page3) pretty soon as i need to
clear up some space for other picts that im going to be uploading.
right click save if you want them. expect them to dissappear within
a day or two.
a day or two.
like mikesj said, in all truthfulness, a bar is bar as long as it holds up...unless of course you are a name-brand *****..
Originally Posted by chiapet15
When will the ARC replica go into mass production?
They are being produced right now as we speak. Hopefully they'll be here soon. I'll keep you guys posted.
Just got my bar today and installed it. This piece is extremely light. The package with the box and foam was 6 lbs. Not sure if I'm the first sedan to have it on but I haven't heard of any other sedans who have this bar. Anyways it fits my '04 without a problem. But note I don't use an engine cover at all. On the highest setting the bar doesn't touch the under part of the hood. Tried the old powder test that Kenchan did to confirm. Guess the sedan hood has more clearance than the coupe hood. There are three things that I had to remove out of the way in order to install the brackets. On the passenger side there is a bracket that holds the wire loom that goes into the battery compartment. This one is easy. On the drivers side there are two brackets. One is to hold down a big aluminum line. This one is easy. The other one is a white plastic bracket that holds another smaller aluminum line and a brake line. This one is a bit harder to move and care must be taken not to damage or bend the aluminum or brake line. Other than that the install is pretty straight forward. As for the performance I'll agree with Kenchan's assesment. The reduction in chasis flex is immediately noticeable. The front is just tighter and you can tell it's allowing the suspension to do more of the work it was intended to do. It felt like the suspension was allowed to absorb and soak up the bumps and dips better on the streets and highway. Haven't driven the car real hard yet but I'm sure I'll notice even more of a difference on the track the next time. Why the G didn't come with a factory strut tower brace is still beyond me. The G really needs it. It's too bad the only options right now are so expensive. But I'd still rather have one than not. The only bad thing about this bar is that the brackets are fashioned in such a way that it makes difficult to almost impossible to adjust shocks that have the adjuster at the top of the shaft.
it's a nice bar. as you mentioned it is a bit ofa pain if you want to adjust the damp settings.... i tuned my damp settings
before so its no issue for me.
im not sure why people are crying about a $500 part... you got a $35k+
car 500 for a car part that actually work well is nothing. i was wondering
the same when people were crying when i got the stillen camber rods.
i say get a better job. lol jk
nice write up.
took some decreasing radius sweeper on/off ramps on the way to work today and the cars attitude definitely felt more planted. i believe the front is getting more grip now. i was a bit of skeptic at first that any of these STBs could do what people have claimed but now i see what they were talking about. i guess if nissan engineers felt that the Z needed it then the G could surely use it as well. now if the bar was triangulated to the firewall that would even be better!
I guess it just comes down to the material which will determine if it will have the same stiffness. The Ti ARC will have the weight advantage, but a few pounds doesn't make a difference on a 3500lb car.
