Vibration when braking....
Old Jul 26, 2006 | 12:38 PM
dumberfeet's Avatar
When I hit the brakes @ speeds from 100 - 155 mph, the entire car vibrates... don't know what it could be, I'm suspecting the pads are shinny and need to run a sand paper through them or the front rotors are bent.... By the way my car is an 05 regular brakes 6mt coupe... Any suggestions greatly appreciated...
Old Jul 26, 2006 | 01:01 PM
Brando's Avatar
Cool
Sounds like your rotors are warped......
Old Jul 26, 2006 | 01:03 PM
Ca$hio's Avatar
Rain man says: Defiantly wrapped, yes wrapped.
Old Jul 26, 2006 | 01:17 PM
pp7's Avatar
pp7
Yep you're warped. Same thing happened with my car and I got the all the rotors machined and the rear pads which were almost completely worn down replaced. This was after 35000 miles. The whole thing cost me somewhere around $350 at WheelWorks. Now braking is as smooth as new. Man where are you able to drive 100-155mph without getting caught?!?
Old Jul 26, 2006 | 01:56 PM
cato's Avatar
SouthernComfort Moderator
Warped rotors for sure!
Old Jul 26, 2006 | 02:28 PM
dumberfeet's Avatar
Let Me Just Add One More Fact..... This Happens Only At High Speeds, Not Vibration Or Wabbling At Low Speeds.... 155 Mph On I-95 Nb Before Delray Bch 0750 Hrs M-f..... Heheheheh
Old Jul 26, 2006 | 04:02 PM
nghiars's Avatar
you might be able to get the stock rotors sanded down but if you're driving at 100-155 quite often.. upgrade your brakes!!! you need to!!!
Old Jul 27, 2006 | 07:23 AM
cato's Avatar
Slow down, problem solved!
Old Jul 27, 2006 | 07:42 AM
dumberfeet's Avatar
Yeah right!!!!!!!!!!! lmao..... I'll probably take them out and turn them myself... I happen to have a lathe.... hehehe
Old Jul 27, 2006 | 10:31 AM
JOKER's Avatar
CLUB MODERATOR
your rotors got over heated in some spots and now when you break those spots are wider then the rest of the rotor so that is where ur vibration comes from
Take it to the dealer and have them spin ur rotors, It is covered by waranty, Free of charge,
and you deff need better rotors if you always drive that fast
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
5150DS
Sep 26, 2015 07:47 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
