What kind of Brake Fluid?
Old Jan 12, 2007 | 10:05 PM
  #31
Texasscout's Avatar
Originally Posted by russky
Went to a shop and they pointed me to Castrol Response Super DOT4. Said I can just top up my current fluid.
Question 1: Can I really do that? Or does the person not know my car? ie. will the brakes work? I drive hard from time to time... (In Australia, Skylines 350GT is an extremely rare car and no one really has any clues about it or parts for it except for the importers).
Yes and no. Yes you can "top up" as it says on the can "compatible with Conventional Brake Fluids", however, how long since you have flushed the system. Should be once a year. Yes your brakes will work just fine, but wouldn't you feel better with clean fresh fluid in the system?
Question 2: If I do fill it up, should I change it with every 6k km traveled? (Thats how often I service my car) or can change with every 12k km (approx 7.5k miles i think)? Reason why I want to top it up is cos its close to minimum and in mornings brake light, slip and VDCoff comes up, so wanna try if it solves my problem. Thanks
If your brake fluid is, as you say, "close to minimum", I would check your brake pads. Most likely you need to replace them. I NEVER "top up" the brake reservoir, when you go to change the pads and push back the caliper pistons, the reservoir will spill over making a paint removing mess!
This weekend I am changing the pads and flushing the brake system on my G. I am using EBC "Green Stuff" pads and Valvoline SynPower Brake Fluid. The next weekend I am going on the Raging Bull Texas Stampede, the fastest, funnest, road rally in Texas. 350 miles of the twistiest roads in Texas. I'll let you know how it goes when I get back. I had no problems with the factory brakes last year. I now have over 41K on them and they still have a lot of wear left.
BTW, this from the Valvoline website:
SynPower High Performance Synthetic Brake Fluid is recommended for ABS, hydraulic drum and disc braking systems and hydraulic clutches requiring DOT 3 and DOT 4 fluids. Its premium, synthetic, low-moisture formulation provides superior anti-vapor lock protection. It has a high dry-boiling point up to 260°C (500°F) that reduces the risk of fluid vaporization and possible brake failure.
Exceeds DOT 3 and DOT 4 specifications
Is designed for most ABS, disc or drum brake systems
Features high boiling point to reduce risk of brake failure
Is compatible with conventional brake fluids
Old Jan 12, 2007 | 10:43 PM
  #32
russky's Avatar
Brake pads are fine. I only got the car in April, and it had just over 30k km on it, and from japan. Got told it was properly services, and knowing japanese, they do everything proper. So I'm thinking of flushing it with the next service ill do in about 6 months.
Thanks for the advice!
Old Jan 13, 2007 | 01:33 PM
  #33
Q45tech's Avatar
The brake pad acts as an insulator as the pad wears the caliper piston gets closer to the hot rotor and thus the brake fluid gets hotter. The mass of the pad decreases [metal backing plate doesn't change] to near nothing. Thus the reason for 2-3 mm MINIMUM pad thickness is to reduce the chance odf fluid boiling.
Worn pads will boil fluid faster than brand new pads.
Why I replace my pads way before the minimum is reached.
Fluid type, age, moisture, and pad thickness are the ways you control fluid temperature and fade.
You can skin the cat in multiple ways.
One must cost analyse the cost of flushes and fluid compared to new brake pads and pick a safe suitable interval for each.
You have pads that fade at 600-800F and fluid that fade boils at 400-250F which is more likely to happen in your case?
Easy to mount a thermocouple between the backing plate and piston to see whats happening on your individual car.
Old Jan 13, 2007 | 01:50 PM
  #34
Q45tech's Avatar
Don't assume shops [in general] know anything about Brake fluid especially chemistry.
They push whatever is profitable.
Members can spend 15-40 hours of research [primarily on web] and learn much more than almost any shop technican in US.
Specialty brake [stoptech, etc] companies may have research chemist or consultants and have a good understanding of the situation.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
cmesidewayz
Sep 29, 2015 09:28 PM
socaldavid
Sep 5, 2015 04:35 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
