Stillen's Master Cylinder brace?
Old Aug 19, 2006 | 08:00 PM
NickS's Avatar
I have to agree... I really hate the soft pedal feel. I put Stoptech SS lines on and put in Motul 600. Bled the system using TWO bottles of the Motul and the brake pedal is still soft. You can tell that the pdeal goes to a certain point and then gets soft or mushy. It has to be the MC flex.
CATO, if you get this I would really like to drive your car if the feel is improved with it.
Old Aug 19, 2006 | 08:36 PM
cato's Avatar
SouthernComfort Moderator
I'm thinking this might be my next mod......
Old Aug 19, 2006 | 08:51 PM
NickS's Avatar
Drop me a line if/when you do please
Old Aug 19, 2006 | 09:14 PM
roko's Avatar
Originally Posted by cato
You have this? Tell me how much improvement in pedal feel there is! I just upgraded my front brakes to a Wilwood BBK with SS lines, rears upgraded with Stillen slotted rotors, metal matrix pads and StopTech SS rear brake lines. This set up is a vast improvement over stock, but the pedal could be alot firmer with the brace?
This will definitely firm up your pedal. Have friend press your brake pedal and you will see how much your m/c dives. I also have BBK with SS brake lines. Then later added the master cylinder brace, for me this made a big difference!
Old Aug 19, 2006 | 09:34 PM
cato's Avatar
Thank you very much! Just what I wanted to hear.
Old Nov 22, 2009 | 05:56 PM
Mustang5L5's Avatar
Bump.
I have the same soft pedal that a lot of people complain about. I have to double pump the brakes to get good feel out of them. I've tried bleeding them many times.
Has anyone with a soft pedal installed this brace and had it completely cure the problem?
Picture Share
Feb 4, 2018 12:41 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
KallDay86
Jan 8, 2016 12:42 AM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
