cusco a-arm question
Old Aug 17, 2006 | 10:20 AM
echephron's Avatar
i have purchased a set and do not believe that they will allow enough of a positive camber adjustment to get my fronts back into spec... right now i'm riding on 245/35 r19 with a 20mm offset... i believe the left is at -1.4" and the right is at -1.5" of camber... i would like to get them both back around -0.7"... can anyone help me with the proper settings (alan bolts) to achieve this?
thanks!
Old Aug 17, 2006 | 01:36 PM
dklau33's Avatar
The cusco a-arms will allow 0.5 of positive adjustment out of the box so you will be at around -1.0 front and left. -1.0 of negative camber is no big deal at all and your tires will wear just fine. Just make sure you get a proper alignment and be sure the toe is set correctly. Out of spec toe will kill tires faster than negative camber. There's also a method of modding the cusco arms to give more positive adjustment if you wish to go that route.
http://www.350z-tech.com/forums/inde...&hl=cusco+arms
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
