What a JOKE
Old Aug 23, 2006 | 09:51 PM
Texasscout's Avatar
1K is a lot for a brake job. Even for the Stealership. I had several quotes that were less than half that from national chains.
It's not that hard to do it yourself. All you need is a few tools and a "C" clamp. The hardest part is finding a place to re-cut your rotors with a "non-directional" pattern. Most places still have the old radial cut machines.
You can do a search and find a DYI on it here most likely. If not there is a lot of info on the web.
You can get a copy of a manual HERE, even if it's not the same year, the process is the same.
Old Aug 23, 2006 | 10:11 PM
cungkpham's Avatar
dealerships dont cut rotors... they just replace them, at least thats how mercedes benz is. but if you had a full brake job, meaning new pads and rotors at all four corners, thats still pretty cheap.
