Is it okay to mix different brake pads?
Old Aug 28, 2006 | 11:36 PM
scorcher76's Avatar
Just installed Monroe Ceramic pads in the front. The back are still using Nissan OEM. I was wondering if it's okay to mix different kinds of pads or should I always stick with the same brand front and rear?
Alex
Old Aug 28, 2006 | 11:41 PM
jjyellow's Avatar
you should be fine
Old Aug 29, 2006 | 08:54 AM
g35rcr's Avatar
you should stick to the same type front and rear
Old Aug 29, 2006 | 09:03 AM
SilverII's Avatar
i run project mu front, oem back.... so far so good. only have a little squeel on slow braking
Old Aug 29, 2006 | 01:29 PM
obender66's Avatar
You are ok
Old Aug 30, 2006 | 10:50 AM
Q45tech's Avatar
Nothing probably beats the oem pads in single or mild back to back stopping from even 120 mph.......changing the friction vs speed of application and the friction vs temperature curve can significantly [say up to 10-15%] INCREASE stops under identical conditions. Whether 12-20 feet longer [worse in wet] is a matter between you and your insurance or the legal system.
When you rear end someone you are always at fault anyway.
Same with changing oem suspension and tires. Take a look at TireRacks test 50 mph braking wet and dry...........identical sized tires can vary up to 25 feet in wet from just 50 mph.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
MrIP35
Oct 25, 2015 11:13 PM
MThawkins86
Oct 24, 2015 02:07 AM
bigmike
Sep 17, 2015 01:58 PM
NJ6MT
Sep 10, 2015 08:40 AM
