Who makes rotors for the 05-06 revised brakes?
Old Aug 24, 2006 | 01:54 PM
johnadlertech's Avatar
I have seen tons of aftermarket rotors in slotted/drilled for the regular 02-04 G35 (& 05 G35x) setup and the brembo setup. But I havent seen any for the revised larger 05-06 G35 brakes (and 06 G35x & 350Z). Someone must make aftermarket rotors.
Old Aug 28, 2006 | 01:52 PM
No one? There must be 50 vendors for the 02-04 smaller rotors and Brembo package.
Old Aug 28, 2006 | 07:39 PM
Clean G 4D's Avatar
I know racingbrake has 05-06 specific rotors. I also saw rotors listed on the stoptech website when you input your vehicle info. -I would check with stoptech (PM him, he is a member here) to be sure that those rotors will work, because they do not specifically state that they are for the 05-06 setup.
Old Aug 28, 2006 | 10:04 PM
trey.hutcheson's Avatar
Don't you have an 05 X? I thought they retained the 03/04 brakes.
Old Aug 29, 2006 | 09:08 AM
yes I do. And yes they do. So I want to get rid of them as soon as I can find a replacement set off a 05-06 RWD. They will work much better (and look better under the wheels I got from you). Actually I should seriously start looking for tires before winter comes first, my brakes turn the front rims black in barely a week.
Old Aug 29, 2006 | 07:49 PM
I would just get a set of replacement rotors for your existing setup and some new pads. Or am I missing something here?
Old Aug 30, 2006 | 10:30 AM
Q45tech's Avatar
Yet there are only 7 cast iron casters in the world that do rotors, Most are in China and supply the finished or unfinished blanks.
Anyone can order rotors, just supply specs and a 2,500 minimum order [44' container full] at say $15-$18 [oem copy] each FOB China. 60 days later unload your rotors in California.
Old Aug 30, 2006 | 11:14 AM
So group buy then?
I still cant believe that that more VENDORS (not manufacturers) dont list the 05-06 larger rotors.
I would rather replace everything with an 05-06 RWD setup then just do the rotors & pads. Time to find a wreck or someone going with a BBK and get their parts.
jsimonk
Dec 22, 2023 03:49 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
miata007
Aug 17, 2015 04:36 PM
sahizzle110
Jul 29, 2015 11:36 AM
RedBaronK
Jul 27, 2015 03:19 PM
