my brakes squeek...but bad
Old Sep 8, 2006 | 03:25 PM
fabulustt7's Avatar
my brakes squeek so bad, i dont know what the problem is. and it is not like a regular squeeeeeeekk...its like metal dragging against metal when i hit the brakes. especially under 20 miles per hour. does anyone know what the problem might be
Old Sep 8, 2006 | 07:03 PM
fabulustt7's Avatar
no help guys?
Old Sep 8, 2006 | 07:19 PM
dklau33's Avatar
Are your brake pads almost running out? I'd check that out. Most brake pads will have a wear sensor on it so that when the pad gets to minimum levels, the little metal tab will scrape against your rotor and give an audible screeching to warn you to change your pads before it's too late and you screw up your rotors.
Old Sep 8, 2006 | 07:52 PM
fabulustt7's Avatar
my pads were just changed, but its not an oem pad i think they are called warner
Old Sep 8, 2006 | 08:01 PM
abcquackyxyz's Avatar
did you do it yourself or you had a mechanic do it? Possibly they didnt put any anti squeal?
Old Sep 8, 2006 | 08:08 PM
gary c's Avatar
Not factory pads................
Other than factory pads most after market pads have
a process for breaking them in. If you didn't install
them go back to where you paid to have the work
done.....let them know the squeeking is driving you
nuts!
Old Sep 8, 2006 | 08:36 PM
fabulustt7's Avatar
i did they told me that they needed to break in but its been about 1000 miles and its still the same a annoying skreech.......
Old Sep 8, 2006 | 09:55 PM
2004v35's Avatar
theres a little tab on the bottom left side that goes into a slot
check that
mine were replaced and that what cuased them to squeek
Old Sep 8, 2006 | 10:12 PM
jetblackg35's Avatar
join the club of bad infiniti brake pads... its common
go aftermarket
Old Sep 9, 2006 | 12:17 AM
TINMAN's Avatar
he did
i say take it back to where you have it installed.
Old Sep 9, 2006 | 12:31 AM
ISMSOLUTIONS's Avatar
What kind of pads were they? There are specific compounds that do not work well with the rotors on these cars as they build too much heat too quickly and will not disperse that heat properly, and begin to immediately harden and crystallize.
Were they kevlar based? Full metallic? Hi performance? Pep Boys specials? Part number and manufacturer?
Rick
Old Sep 9, 2006 | 05:18 AM
Dan_K's Avatar
I have started to hear a squeak when I am braking under 20mph as well. I looked at the pads and there is about 3mm left and the "brake" light has not come on yet. Should it be squeaking? I have 25k miles right now on stock brembo pads.
Old Sep 9, 2006 | 09:34 AM
Sounds about right...
Old Sep 9, 2006 | 02:43 PM
dklau33's Avatar
The "brake" light will only come on if your fluid level in the master cylinder reservoir gets too low. And 2mm is the min level for your brake pad so your pad wear sensor is probably hitting your rotor now telling you it's time to change the pads.
Old Sep 9, 2006 | 03:07 PM
bull3t's Avatar
they probably didnt put your old shims back on the new pads...im sure this will solve it...
