SKUNK 2 SRPINGS to low???
Old Sep 17, 2006 | 06:41 PM
nfo184's Avatar
wondering if i should get the SKUNK 2 SRPINGS LOWERS APPROMIMATELY 2.0"-2.5" or the
Tein S tech with a spring rate of 358/274 lowers 1.2"front /0.9"rear for my 2004 sports coupe g35
I know Tein have a great reputation and smooth ride but I dont know if people had problems with the skunk2 springs or with a bad camber and ride and too low for a lip kit
Old Sep 17, 2006 | 11:57 PM
Dan_K's Avatar
2" drop is a lot. You will probably be rubbing really bad and the tires will be tucked. Either way, you should get a camber kit for at least the rear, if not both front and rear.
Old Sep 18, 2006 | 01:49 AM
insydiusg35's Avatar
I'd go with adjustables; sleeve or full coilover. You might regret the 2" drop once you ride on it. However, with adjustables you can always change the drop. Good luck!
Old Sep 18, 2006 | 06:00 AM
nfo184's Avatar
like a Tein basic damper system maybe????
Old Sep 18, 2006 | 07:37 PM
2006_G_coupe's Avatar
Nothing is too low... lol
Old Sep 18, 2006 | 10:42 PM
nfo184's Avatar
when will i have bad camber? is 1.5inch bad? or the tein s tech 1.1" drop???
Old Sep 18, 2006 | 10:48 PM
Jtrain's Avatar
oh god
Old Sep 20, 2006 | 10:56 PM
nfo184's Avatar
Old Sep 20, 2006 | 11:00 PM
jclit's Avatar
After 1 inch youll have camber problems.
Old Sep 20, 2006 | 11:04 PM
nfo184's Avatar
will any camber kit fix this?
nfo184's Avatar
and how bad will it wear and show on the tires?? my friend had such bad camber on a 2" drop it wore the tires within 1 month
Old Sep 21, 2006 | 06:10 PM
nfo184's Avatar
Old Sep 22, 2006 | 03:00 AM
Triple8Sol's Avatar
With the Hotchkis Z springs I have, it's probably a little over a 1.5" drop all around? I scrape my Y-pipe flex section like a ****. Can't get an alignment at most shops, and can't even make it onto a damn alignment rack or lift without 2x4's
Old Sep 22, 2006 | 06:11 PM
a0alvl's Avatar
I have mine at 1.6" and 1.4" and it's worthless as a car. I'm switching to a more conservative drop. Cant get it on lifts, can't drive half the parking lots or garages I need to go into for work, and as triple8 mentioned my y pipe is gettin scraped up like no ones business.
Old Sep 22, 2006 | 07:20 PM
nfo184's Avatar
can you measure from the ground to the bottom of the rear bumper and the bottom of the front bumper?? on a flat service.....also do u have a lip kit or the oem lip aero package?
