wheel bearing??
Old Oct 22, 2003 | 09:49 AM
davey2003's Avatar
wheel bearing??
At speeds between 10 and 25mph i get this squeek, kinda like a wheel bearing coming from the left side. It goes away while I brake and comes back a couple seconds later after I release the brake. I'm sure that this is a wheel bearing sound but I just want to make sure before I go to the dealer. Also has anyone else gotten this and will it be covered under warranty?
Old Nov 16, 2003 | 06:39 PM
Msedanman's Avatar
O.F. Administrator
Re: wheel bearing??
I very much doubt it's a wheel bearing. It would have to be bone dry for it to squeak. It's prolly a glazed brakepad causing the noise. This is a common issue with our G's .
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 16, 2003 | 07:45 PM
GGGGGGGG's Avatar
Re: wheel bearing??
I don't think it's the wheel bearing. Because it should be a grinding sound. And as you accelerate, the pitch of sound will increase and then kinda disappear at a higher speed. Anyway, should this be the wheelbearing, it wil definitely be covered by warranty.
Old Nov 17, 2003 | 08:38 AM
GIlovemycar's Avatar
Re: wheel bearing??
If it is coming from the rear, I quarantee that its the spring on the rear brakes that goes across the tensioner for the e brake. I had the same noise and had the dealer look at it he said he counldn't find it but after my friend and I took the rear rotor off, for some reason the spring had come off and was rubbing against the rotor. When I first took it to the dealership I described it as a wheel bearing.
Old Nov 17, 2003 | 02:15 PM
tonke73's Avatar
Re: wheel bearing??
If it were the wheel bearing, it would be constant at all speeds and get louder the faster you go as other members have mentioned. It's probably the brake pads and nothing I'd be concern with unless it lasts a long time.
Old Nov 17, 2003 | 06:30 PM
davey2003's Avatar
Re: wheel bearing??
Thanks for the help guys, recently I just noticed that its happening at higher speeds now. I'm gonna go to the dealer with this and see what they say when i get my oil change soon. Again, thanks
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
rping
Jul 26, 2015 09:53 PM
