Cutting OEM Springs
Old Sep 26, 2006 | 04:57 PM
SD_G35's Avatar
Cutting OEM Springs
I did a search and didn't find anything about this. Has anybody done this before? In lowering our G, since we always want close to stock, would it be possible to just cut a portion of the stock springs instead of replacing it? Start at 1.5" off the tip until desired height is achieved. It would seem logical, right? I am sure the ride should be the same as stock except it's lowered. What do you guys and gals think?
Old Sep 26, 2006 | 05:44 PM
dklau33's Avatar
Better put on your flame suit....
Old Sep 26, 2006 | 05:55 PM
az1anbeethoven's Avatar
^^^+1,000,000...dood...dont ever cut your oem springs...get some eibachs man
Old Sep 26, 2006 | 06:06 PM
MixturePinoy's Avatar
Cut 4 coils off, and not take off the tires and rims when you do it. just jack up the car and cut them from there. easy
Old Sep 26, 2006 | 06:36 PM
richboy's Avatar
MORE POWER PLZ!!!
When did this become a civic forum
Old Sep 26, 2006 | 06:49 PM
g35cas's Avatar
Don't do it. If your cheap, buy some 350z springs for $50. Much better idea.
Old Sep 26, 2006 | 07:19 PM
SD_G35's Avatar
I already had the 350Z H-Tech installed yesterday at Creative Works in San Diego (Thanks James and Del). However, the idea came when I put the H-Tech and the OEM spring side by side. The H-Tech is a little bit shorter as compared to OEM spring.
Old Sep 26, 2006 | 08:03 PM
kenchan's Avatar
spring rate will determine ride height too, not just the length of the coils in a
relaxed state.
Old Sep 26, 2006 | 08:08 PM
2006_G_coupe's Avatar
LMAO.!!
Old Sep 26, 2006 | 10:01 PM
Hugen35's Avatar
Trendsetter
uhhhhh......
Old Sep 27, 2006 | 11:31 PM
skeleton_cru's Avatar
Sedan
Old Sep 27, 2006 | 11:33 PM
Andy2434's Avatar
^^^^ Lmao!
Old Sep 27, 2006 | 11:36 PM
ADHD's Avatar
definitly some **** you do on a civic!! Not a luxury car bro!
Old Sep 28, 2006 | 02:24 PM
Fox233's Avatar
Thats like the **** they did in the 1950's before lowering springs were around....jesus. LOL
Old Sep 28, 2006 | 06:10 PM
jasonlee4180's Avatar
Dang....if you can't afford a set of $150 springs...i don't know how you manage to own a G35. The last time I'd heard these ideas was in a civic forum where the majority demographic were dependent kids. I say just don't do it if you can't afford to do it properly.
Albeit $150 is not chump change, it doesn't take long to save over a span of several paychecks. Just eat like your in college for a couple weeks and there you have it.
