Teid Flex rear noise problem
Old Oct 8, 2006 | 03:44 AM
y.dan's Avatar
i just got mine on yesterday.. and does anyone else suffer from the noise/rattling problem from the rear?
any solutions?
also, from the setting "0" softest to "16" the hardest can you actually feel the difference?~
yea.. sorry.. bad mispelled~
Old Oct 8, 2006 | 06:05 AM
Alan's Avatar
yes, none that i know of, definetly yes
oh yeah change "teid" to "tein"
Old Oct 8, 2006 | 05:08 PM
caskyline's Avatar
Former Vendor
The top nut on the strut does not allways come tight from Tein.If it is loose the strut will make noise.Also if the EDFC is not on correctly it can fall off and rattle around.The only way to check is to remove the struts and look.
Old Oct 12, 2006 | 01:05 AM
Alan's Avatar
i had my mechanic tighten that top nut and it didnt help
Old Oct 12, 2006 | 01:15 AM
Knight's Avatar
I'll have to agree, there is nothing you can really do about the rattle noise. I have the Tein CS & I find the rattles very annoying too. I've looked at the entire setup & everything is tightened.
Be careful when adjusting your dampening, I've heard of many cases where you rotate & click more than 16 levels (even though it only has 16 levels). As well the clicks aren't very defined.
Old Oct 12, 2006 | 01:13 PM
kenchan's Avatar
yep, very typical of TEIN coilovers. the only ones that didn't rattle on
my old car was the TypeNA which they don't sell anymore...
Old Oct 12, 2006 | 02:04 PM
caskyline's Avatar
Former Vendor
I have had no problems with my Tein Flex in over 1 1/2 years.You could also check your sway bar links,they sometimes make noise.
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
Jussaku
Jul 29, 2015 11:45 AM
rping
Jul 26, 2015 09:53 PM
